The CHMSL on my '09' stays "on" continuously, ignition on or off. Has anyone ever had or heard of this? Haven't talked to the dealer yet, just wondering.
That is a strange one. I've not heard of that before. If it were a brake pedal position switch it seems to me that it would be the brake lights on the rear as well. It could be an issue with the BCM. It sounds like a trip to the dealer is going to be in order. Are you able to get at the codes with a code reader?
The service manual notes that it could be the stop lamp relay. If so you should see P0719 or P0724 in the list of active codes.
Just fixed mine - remove either one of the passenger side tail lights and find the large connector that goes to the tail lights, unplug it, clean the corrosion inside the connector, plug it back together, and it's fixed.
