So i have an 07 convertible and i really really hate the keys. I was wondering, i know u gan get up to 4 keys at a time so, can i buy the new key design with the integrated key and have it programed with my car or can u only program it with the new 08-09?
Also every one with the old design, do u cary around the emergency key or leave it at home?
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
The only key I have on my '07 FOB are house keys (my 2nd FOB does have the key however).
I cut the plastic off the 1st FOB's key (which makes it nice and flat) and keep it in my wallet. Of course, the FOB stays in my pocket unless I'm arriving home anyway. So far, no problems..
I carry them both. But just in case I have a second key with the black "head" ground down to the minimum required to still be functional and I carry that in my wallet. It's come in handy a couple of times.
Carry the fob by itself on a small snap hook attached to my right front belt loop. Did buy one of those rubber "jackets" for it. Makes it a little thicker but since not in pocket, not noticable. Emergency/console/glove box key, house key and one small "special" key in my left front pocket.
Electrically all the fobs are the same...check GMPartsHouse post about the metal key though...it may or may not work.
There was talk about this when the new key FOB came out. The new FOB will work on your Vette, but you will need to change out the lock cylinder above the license plate to use the emergency key.
Change the cylinder and get the key cut to fit it. I think Gene sells the cylinders and the keys. Programming the fob is the same. David
My FOB stays in the little front pocket of Levis all day it never falls out.
Vette key on key ring with all other keys.
We have 4 rides; all are set up the same. You take whatever set up for the vehicle your taking.
Fob and car key is together along with the house key... We can get in the house by using the garage remote, but twice have had a power failure so having a house key is necessary!
With the Vette always have the fob/key on your person; this is doubly true if your locks are set to passive activation!
