Trapped
Old Apr 8, 2009 | 06:29 PM
luvlake's Avatar
luvlake
Default Trapped
I have an 08 vert. Several times after I turn off the car and don't get out for a while I have to pull the door release on the floor to exit. It happens infrequently, is there something I did or should have done to not have to go through this exercise?
Old Apr 8, 2009 | 06:31 PM
ron-z51's Avatar
ron-z51
Try unlocking the doors
Old Apr 8, 2009 | 06:32 PM
jdurhan's Avatar
jdurhan
So your not trapped. I want my click back.
Old Apr 8, 2009 | 06:35 PM
raider4251's Avatar
raider4251
Is this another Blondestar thread?
Old Apr 8, 2009 | 06:37 PM
RanGer498's Avatar
RanGer498
Old Apr 8, 2009 | 06:39 PM
LMB-C6's Avatar
LMB-C6
Seems odd if the fob is still in the car. Maybe the fob battery is going dead?
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
was the top down like in your avatar?
Old Apr 8, 2009 | 07:13 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
OK here you go
Old Apr 8, 2009 | 07:31 PM
mikez51c6's Avatar
mikez51c6
St. Jude Donor '11
Old Apr 8, 2009 | 07:36 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Ibtb :d
Old Apr 8, 2009 | 07:51 PM
luvlake's Avatar
luvlake
The top was up, didn't try to unlock the door, just pushed the button. I guess the question is, is there a time limit after which you have to unlock the door before trying to get out after stopping the car? It's not a big deal, just wonderiing what the ground rules are......
Old Apr 8, 2009 | 08:04 PM
mcandrew67's Avatar
mcandrew67
Pretty much about 10 mins, until the radio turns off. If you hit the unlock button it should unlock the door after that.
Old Apr 8, 2009 | 08:05 PM
Vette_DD's Avatar
Vette_DD
If you have autolocking set, the doors normally lock 8 seconds after you shut the door, but I don't know how that timing interval works if you never get out of the car.
My suggestion would be to just leave autolocking turned off if you're going to do that very often.
Old Apr 8, 2009 | 08:06 PM
danl72's Avatar
danl72
Old Apr 8, 2009 | 08:07 PM
GotVett?'s Avatar
GotVett?
Old Apr 8, 2009 | 08:08 PM
dpigguy's Avatar
dpigguy
this procedure worked my issues with same problem. also make sure you have the e-brake on or else seat memory, etc. won't work as well.
Old Apr 8, 2009 | 08:09 PM
WAwatchnut's Avatar
WAwatchnut
I've never had that happen. I've sat and waited in the car several times, and never noticed having any problem opening a door. I thought the fob would still be sensed as soon as you go to hit a button (starter, door open)???
Maybe I didn't end up getting out of the car, so I just didn't notice the same issue, but it sounds like a problem, and not SOP.
Old Apr 8, 2009 | 08:12 PM
johnodrake's Avatar
johnodrake
Moderator
But only after the door is opened and closed and the car detects that at least on fob has left the car. Open and close the door still sitting in the car and (if you have this feature set) you will get three horn chirps.
Door should open when you press the button just like if you pressed the pad from the outside. Have you tried pressing the unlock on the fob then the door button? Should not have to do that, just wondering if you had.
Old Apr 8, 2009 | 08:14 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Could be a bad door module or switch?
To Trapped
