HELP! Drivers window won't move
Help! I changed door panels on my car, now the driver's window will not move. It is in the down position and you can hear it click when you use the window button. Tried the original door panel/switch, same clicking noise.
Any ideas what could have happened? I can't get the top up because I can't index the window!
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Did you try it from the inside with the door closed?
You can also "close" the latch on the door/latch jam to simulate the door being closed. It should go up now so it can be indexed. Hit the door open button to Open the door before closing it against the closed latch.
You may have to do the battery disconnect thing also to reset the computer.
tried the battery trick already ,didnt work. I actually found the answer on accident. The door has to be closed when you roll it up the first time. After that, it will work with the door open, go figure. Thanks for the quick response.
I learn something here every day...never would have thought of this!
Everyone, thanks for the quick response and the accurate info.
Never in a million years would I have expected that the door had to be closed the first time to operate the window!
You guys saved me a trip to the dealer. Way to go
46490 and I found this out also when we installed Crazy Cowboy's insulation on our cars. We also found out that after hooking up the battery the Vert's windows must be up for the top to close. Of course the first thing it does is drop the windows.
