What do you think?
Old Apr 21, 2009 | 10:56 AM
corvettestevec6's Avatar
corvettestevec6
Default What do you think?
Do you think I should adjust these (exhaust) more towards the center??
Old Apr 21, 2009 | 12:19 PM
corvettestevec6
any suggestions??
Old Apr 21, 2009 | 12:20 PM
DossC6's Avatar
DossC6
looks nice to me, what system is that?
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
I think I would like them more towards the center. But they look fine there also
Old Apr 21, 2009 | 12:21 PM
STEVE MC's Avatar
STEVE MC
Yes, move them in. They are too far apart.
Old Apr 21, 2009 | 12:22 PM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
or put something between them. Looks like a gap in teeth.
Old Apr 21, 2009 | 12:47 PM
car2fast4you's Avatar
car2fast4you
I think the spacing of the tips looks fine.
Although it appears that they're a little crowded against the rear diffuser.
For that reason, I'd push them inward.
Old Apr 21, 2009 | 12:49 PM
ALD_Z06's Avatar
ALD_Z06
Old Apr 21, 2009 | 01:30 PM
corvettestevec6
yea, I was thinking of pushing them inward. What's the best way to do this? Loosen the hangers and push?
Old Apr 21, 2009 | 01:38 PM
6SPDRCR's Avatar
6SPDRCR
Old Apr 21, 2009 | 01:49 PM
redzone's Avatar
redzone
There is no adjustment....they are suspended in rubber grommets.
Old Apr 21, 2009 | 01:54 PM
corvettestevec6
What do you mean there is no adjustment?? Like I can't move them at all?
corvettestevec6
Flowmaster American Thunder
Old Apr 21, 2009 | 01:57 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
do you have them backwards?
left were the right should be??
I've seen it a lot lately.
Old Apr 21, 2009 | 02:08 PM
corvettestevec6
I've tried figuring that out, but there is no serial numbers on the mufflers to find out. There is only patent numbers. The over axle pipes are in the right location though.
Old Apr 21, 2009 | 02:11 PM
vdavenp802's Avatar
vdavenp802
Gotcha. I'll bet this is what happened. Looks okay to me, as long as the tips don't rub on the diffuser, which looks like they don't.
Old Apr 21, 2009 | 02:12 PM
corvettestevec6
The flowmaster logo on the mufflers are currently facing each other. Like if you were to look under the car, the Flowmaster logo is on the inside of the muffler. I wonder if the Flowmaster logo is suppose to be on the outside, like facing the rear tires.
To What do you think?
Old Apr 21, 2009 | 02:19 PM
pmj341's Avatar
pmj341
if the over the axle pipes are right I would chage the mufflers, the rear supports
will determine where they end up!!
Old Apr 21, 2009 | 02:27 PM
corvettestevec6
I'm trying to figure out for sure if they're in the correct spot or not. The instructions don't really help that much. They say there should be numbers on them, but there isn't.
Old Apr 21, 2009 | 02:39 PM
pmj341's Avatar
pmj341
I'm almost dead sure the mufflers need to be swapped,
call the manufacturer and describe the problem, they will help you!!
