Lug Nuts Size
Old May 16, 2009 | 05:42 PM
Mad*Max's Avatar
Mad*Max
Default Lug Nuts Size
I was trying to buy a wrench to open the nuts and it appears that the Imperial one I bought (smallest size on it was 3/4") is not the right size.
I did a search here and even read the manual but there is no mention of the size.
Old May 16, 2009 | 07:00 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Everything is in metric sizes...for the lug nuts you need a 19mm deep socket.
Old May 16, 2009 | 07:01 PM
cajun man 08's Avatar
cajun man 08
Default lug nuts
Just bought a socket for my torque wrench found out it's metric 19mm on standard c6 wheel.
Old May 16, 2009 | 07:06 PM
Vetteinplano's Avatar
Vetteinplano
3/4" works also.
Old May 16, 2009 | 07:08 PM
shopdog's Avatar
shopdog
3/4 inch is 19.05 mm, so a 3/4 wrench is almost the same as a 19 mm wrench. Either one will work. The 19 mm one will fit a little tighter.
Old May 16, 2009 | 07:13 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by Vetteinplano
3/4" works also.
Thanks, so it is normal to feel a little play? I am worried that I might damage the nuts' finish.
Old May 16, 2009 | 07:23 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
I never had that problem...."to feel a little play"....
To Lug Nuts Size
