shell vs chevron
Old May 20, 2009 | 03:27 PM
avbump's Avatar
avbump
Default shell vs chevron
Just noticed that shell is advertizing "v power" with nitrogen...I've been using chevron with techron for years & have had numerous problems with the fuel system. The dic reads check gauges, I do & the fuel gauge says empty when I'm full. It's been in the shop @ the local dealership twice. First time they recalibrated the sending card, second time they dumped a bottle of fuel system concentrate cleaner in the tank...(do I qualify for the G.M. buy back program?)...they said next time they will drop the tanks etc. & do a VISUAL on all the components & replace what they think is necessary! WTF??? This is their FIRST & ONLY Corvette with this problem. They say it's a fuel problem, I suspect something else. I only use 91 octane, that's all we can get in Calif. Any & all advice would be appreciated!
Old May 20, 2009 | 03:31 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
It's a mechanical/electronics problem rather than a fuel problem. Would a change in fuel would help but I would guess not
Old May 20, 2009 | 03:36 PM
CQRT's Avatar
CQRT
degaux's Avatar
degaux
I've used both in mine without issue.... did need to have the "sender" replaced - but that was 4 years ago - no guage problems since...
Old May 20, 2009 | 03:38 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
It's not a fuel problem unless there's something wrong with the stations you've been going to. It'd also have to be more than one station, assuming you go to more than one.
Old May 20, 2009 | 04:05 PM
cranky's Avatar
cranky
They are both top tier gas. This is what gm specifies for the vette.
Old May 20, 2009 | 05:16 PM
phileaglesfan's Avatar
phileaglesfan
I wouldn't rule out the gas station being the problem. It doesn't take much to screw up the system.
Old May 20, 2009 | 06:25 PM
Walkthedog's Avatar
Walkthedog
My bet is station problem compounded by dealer. Try exclusively differrent set of stations.
Old May 20, 2009 | 08:23 PM
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Sulphur???
Here in the midwest back around 04 or 05, we had issues with a lot of the independant stations. The problem was too much sulphur in the gasoline. Ashland/Marathon/Mobile, spent millions repairing fuel sendinig units in the fuel tanks. I had a 96 chrysler and a 98 Indy Pace Car that both had to have the sending units replaced. Mobile paid for both vehicles to be repaired . I now only run Chevron or Shell in the Vette or any other V8 that I own. I run a can of Techron through Vette about every 6 months just as a precaution.
Old May 20, 2009 | 08:28 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Been running Shell 99% of the time and Chevron the other 1% in both my C5Z06 and C6 coupe with zero problems with the fuel gauge
Old May 20, 2009 | 08:31 PM
johnebgoode's Avatar
johnebgoode
All I use is Shell.......no issues.
Old May 20, 2009 | 08:36 PM
danl72's Avatar
danl72
Al I use is Chevron and I have not had any issues. That is what I used in my C5 as well. It is probably the fuel sender. I had it replaced in my C5, but nothing in my C6.
Old May 21, 2009 | 02:47 AM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Just as a side note, I moonlighted for awhile helping out a buddy of mine who operates a chain of Shell stations up in Alaska. According to him, and he's been in the retail fuel business for years, Shell V-Power and Chevron's Techron are the same fuel. Apparently the same truck fills both the v-power and techron tanks up there.
Of note.
Old May 21, 2009 | 02:56 AM
User 81424's Avatar
User 81424
F**k Chevron and Chavez, I boycott Chevron.
Old May 21, 2009 | 03:33 AM
beachfrontvette's Avatar
beachfrontvette
If you are going to boycott something, at least get the facts right!!
Chevron is all American. Citgo is chavez.
Old May 21, 2009 | 03:48 AM
4thC4at60's Avatar
4thC4at60
Beat me to it, thanks.
Old May 21, 2009 | 04:05 AM
User 81424's Avatar
User 81424
Got them switched in my head
To shell vs chevron
Old May 21, 2009 | 04:27 AM
4thC4at60's Avatar
4thC4at60
That's not surprising, you're Army.
Joel Jacobs
22 years Navy
Old May 21, 2009 | 07:05 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Gotta watch out for the doggies........
Old May 21, 2009 | 07:12 AM
Hairbag's Avatar
Hairbag
Boycott Shell--------there not an American company.
