Performance Pads Grinding
If you're good to go for higher speed bedding I'd try re-bedding the pads....sometimes it can take multiple times. I'd think after the initial bedding procedure you could start to really lay into the brakes from higher speeds...60 even up to 80 mph.
Here's a good link for bedding brakes:
http://www.zeckhausen.com/bedding_in_brakes.htm
If the grinding was more of a 'judder' (vibration) type noise I might think the rotors were bad but in-as-much as they're new I would doubt that. Good luck!
Your "grinding" desdcription gives me cold chills!
Could it possible that you have one (or more) of the pads installed backward? If so, you are eating up one (or more) of your rotors by having the metal backing of the pad against the rotor instead of the friction material against the rotor.
If your "grinding" sound is relatively loud, this is probably the cause.
Don't go to bed tonight until you check it out (and post your finds back to the Forum).
R
b
The pads are, fortunately, installed in the correct manner. My son-in-law and I checked as we were installing them. I also checked the rotors to see if the there was any sign of grooving or abrasion. The folks at West Coast Corvette said "That is the nature of those pads. As they heat up is should get a little better. When it comes to performance these are much better but they are a little noisier."
Specifically, the pads are Hawk HP Street Pads and the rotors are AC Delco Slotted and Drilled.
The only coating on the rotors was an oily substance (probably for shipping) that burned off pretty quickly during the bedding process. In fact, they were smoking a lot. Scary stuff!
Thanks for the update... earlier today, I was wondering if you had solved the mystery.
Drive safely!
R
bThe pads are, fortunately, installed in the correct manner. My son-in-law and I checked as we were installing them. I also checked the rotors to see if the there was any sign of grooving or abrasion. The folks at West Coast Corvette said "That is the nature of those pads. As they heat up is should get a little better. When it comes to performance these are much better but they are a little noisier."
