different driving modes
Old May 29, 2009 | 06:46 AM
noenvybu's Avatar
noenvybu
Default different driving modes
When do you guys use the different driving modes..active handling traction,competitive driving,traction control off. Or is this just a gimmick??
I enjoy using paddles, traction system activated mode..Sorry, if I confused some.
Old May 29, 2009 | 07:30 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
I like competitive on most winding road and traction control the balance of the time.
Old May 29, 2009 | 09:02 AM
C6CPA's Avatar
C6CPA
Competitive driving mode if I am using the paddles.
Old May 29, 2009 | 10:59 AM
coryvte's Avatar
coryvte
Driving Modes
1) Automatics.....drive like old guy
2) Manual with TC and AH ON......see 1
3) Manual with TC OFF.......burn the rubber in a straight line, two actually.
4) Manual with COMP Mode......corner sliding is fun!!!!!
5) Maunal with all help off.....all hell breaks lose!!!!!!
Old May 29, 2009 | 11:46 AM
Wayne O's Avatar
Wayne O
CF Senior Member
For normal street driving I leave full AH and TC on. Whenever going WOT I always shutoff TC (or use comp mode) as I don't want the system fighting my efforts to accelerate. If I need to feather the throttle I'll do it. I run road course events and I'll use comp mode about 70% of the time. On some courses even in comp mode I find the system intervening way more than I'd like. In which case, I shutoff all nannies.
TC and AH aren't a fail-safe but they're definitely not a gimmick either. These controls cannot overcome the laws of physics but in certain circumstances their intervention might just save you and your car from disaster. Comp mode shuts-off TC and relaxes AH allowing greater tolerances for sliding or drifting the car. This is essential for running a road course. I once went onto a road course without having one of my tire pressure sensors properly registered and accordingly I could not get into comp mode. Even on the first warmup lap the system was intervening on virtually every corner. It was flat dangerous IMO. I expect the car to handle in a certain manner and when it doesn't it totally screws you up. I got off the track pronto and made sure the TPS's were all registered so I could access comp mode again.
Old Jun 7, 2009 | 01:02 AM
09C6VRGG's Avatar
09C6VRGG
Originally Posted by coryvte
Driving Modes
The A6 is definitely not for driving like an old person. It has an S mode for 6500 RPM shifting I think you are and banned if I am not mistaken.
to the OP, the cars manual explains each function.
Old Jul 24, 2009 | 02:01 AM
CorvetteHulk's Avatar
CorvetteHulk
Default 09c6vrgg
09C6VRGG - If the car shifts@6,500 rpm in "S" mode, then what rpm is it programmed to shift@ in "D" mode??
Hulk
Old Jul 24, 2009 | 02:10 AM
Vette Suspension's Avatar
Vette Suspension
That is for sure.
Sad that some do not appreciate what both the manual and the auto can do. They also both have some good points and bad points. Only a fool under estimates either tranny.
To different driving modes
