M2W Testing
Old Jun 1, 2009 | 11:05 PM
N62XS's Avatar
N62XS
Default M2W Testing
I had a shop install my M2W with a deadman pedal switch. The flaps on the mufflers are not closing. What are the trouble shooting steps you have used. How do I disconnect it and keep the flaps closed?
Old Jun 1, 2009 | 11:24 PM
Mark VerMurlen's Avatar
Mark VerMurlen
Did the car come with NPP mufflers or did you add them with a separate vacuum pump? I believe you have to have vacuum at the flaps in order to keep them closed.
- Mark
Old Jun 2, 2009 | 06:47 AM
SonOfDreams's Avatar
0SonOfDreams
Former Vendor
St. Jude Donor '09
PM Sent
Old Jun 2, 2009 | 07:01 AM
N62XS's Avatar
N62XS
PM reply sent. Car has Z06 cat back added, not stock at delivery.
Old Jun 2, 2009 | 07:06 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
If the Z06 system was added aftermarket did you add a vacuum source to drive the butterfly valves?
Old Jun 2, 2009 | 07:11 AM
N62XS's Avatar
N62XS
Yes, M2W. All lines are connected.
Old Jun 2, 2009 | 07:16 AM
0SonOfDreams
Former Vendor
St. Jude Donor '09
Trouble shooting steps PM'ed
Old Jun 2, 2009 | 08:21 AM
talon90's Avatar
talon90
NCM Ambassador
I'm assuming this reply was intended for my question on the vacuum source. Just for clarification, the M2W is not a vacuum source. The M2W (Mild to Wild) is a switch that plugs in to the foot well fuse panel to allow the operation of the all ready existing vacuum system in a car with a factory installed NPP or Z06 dual mode muffler set up. It can also be used in conjunction with a third party vacuum system to allow the valves to operate. For example, the package called NPP in a Box from forum vendor Nakidparts.
I trust from your reply that you have installed the NPP in a box system. If that is the case, it appears that Eric is working with you via PM to troubleshoot the install and operation. Hopefully you get it straightened out.
Old Jun 2, 2009 | 08:36 AM
kev1n's Avatar
kev1n
default behavior of the flaps when the car is off = open.
With the car on and the switch engaged it should be closed- check the wiring to the fuse box make sure its grounded etc.
Old Jun 2, 2009 | 08:44 AM
0SonOfDreams
Former Vendor
St. Jude Donor '09
Thanks, it is NPP in a box with a foot switch, all issues addressed with customer so we can close this one
Old Jun 2, 2009 | 09:53 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
To M2W Testing
