Repair or replace?
Old Jun 30, 2009 | 10:00 AM
VettedCandidate's Avatar
VettedCandidate
Default Repair or replace?
I've just gotten a chip in my windshield about the size of a large pea right below my eye line and (for me) is just blocked by the top of the steering wheel. I do have insurance. I have never had to replace or repair a windshield. In your humble opinions, is this something you would have repaired or replaced?
Old Jun 30, 2009 | 10:17 AM
Rule292's Avatar
Rule292
St. Jude Donor '11-'12-'13-'14-'15-'16
No spider cracks that's good.
Since it's a repair I would suspect your insurance would pay 100 per cent and waive your deductible.
I would say repair unless you find it distracting or annoying.
Old Jun 30, 2009 | 10:18 AM
PO10TIAL's Avatar
PO10TIAL
I've had about a dozen windshields repaired successfully for about $70.00 each time. Here in NY there is a company named Safelite, they came to my house and to my office and did it right in front on me..... I'd rather pay $70.00 then rip it out and replace it. Tha t doesn't look to bad.
Old Jun 30, 2009 | 10:20 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
I had mine done on my 09 two months after I got the car. Same company cost me $100.00. Most of th time I can't even see it even when I am looking for it.
Old Jun 30, 2009 | 10:28 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I'd go with the repair first. They will come out and drill a hole and clean out the chip. They will then put on a pressurized unit that will inject a clear epoxy in to the chip which will allow it to flow out in to any of the edges that could propagate a crack later. Once repaired it will be virtually invisible if done correctly. You will have to know where to look and at just the right angle to even see it.
Having seen what the removal of a Corvette windshield looks like I will always opt for the repair before replacement and I have full glass coverage on my car with zero deductible.
Old Jun 30, 2009 | 10:29 AM
dvilin's Avatar
dvilin
I would give the repair route a shot, can always replace later if there is a need.
Old Jun 30, 2009 | 10:32 AM
metal's Avatar
metal
I would also go this way first. A chip is lot's better than a crack and I have also had success with the above proceedure.
Old Jun 30, 2009 | 11:00 AM
Wayne O's Avatar
Wayne O
CF Senior Member
With full glass coverage I had never repaired a chip or small crack...I've always just replaced the glass. Not long after getting my new C6 I got a small ding (like you) right in my line-of-sight. Not wanting to replace the windshield in my then new C6 I opted to repair it.
I was surprised with how well it turned out. You really have to look hard to find where the repair was made. I know some dings can't be repaired but the repair person should have a good idea beforehand if your damage can be repaired or not. I'd give the repair a try. Worst case and it doesn't turn out well...you replace the glass. Good luck!
Old Jun 30, 2009 | 11:38 AM
VettedCandidate
Thanks guys...my insurance just scheduled the repair via Safelite (sp?) and they are waiving the deductible.
Old Jun 30, 2009 | 11:58 AM
Rule292's Avatar
Rule292
A happy ending. Sweet!
Getting something free is always a pleasant surprise.
Old Jun 30, 2009 | 12:04 PM
danl72's Avatar
danl72
Good.
Old Jul 2, 2009 | 11:57 AM
VettedCandidate
Default A follow-up...
Just had the windshield repair folks do their thing and I have to admit I am disappointed.
They tell you immediately that this is to try to save the windshield damage from spreading AND that it may create more cracking than existed already. I now see more cracking (about 1/4" to 1/2" on each side of the chip) after the repair but it is slight. It certainly didn't make it in any way invisible. Fortunately, that is still covered by the top of the steering wheel. I just hope that it really works to keep the crack from spreading.
They do warrant it for the lifetime of the repair but they do not warrant it from spreading???
BTW, Safelite does NOT drill a hole into the windshield anymore as part of the procedure.
Old Jul 2, 2009 | 12:01 PM
Rednblack's Avatar
Rednblack
I've had great luck with the repair if the "line of sight" thing didn't bother you. When the glass gets pitted to the point you can't stand it, replace it then.
Old Jul 2, 2009 | 12:03 PM
glennhl's Avatar
glennhl
One other thing to consider is how old and pitted the windshield is. I can't believe how pitted my 06 windshield has gotten in a short amount of time. If I get a chip, I'm opting for a new windshield.
Old Jul 2, 2009 | 12:51 PM
PostalAV8B's Avatar
PostalAV8B
Veteran: Marine Corps
St. Jude Donor '11
If ins does not cover the glass. Major part chains sell a kit for $15. It has 4 suction cups attached to a resin chamber. Used it to repair numerous chips on my old DD. Follow the directions, you get one shot at it.
Old Jul 2, 2009 | 02:40 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Good choice. Trust me ~ put off replacements as long as you can... potential for other problems like rearview mirror "wiggle", poor sealing, etc. Not worth the gamble unless absolutely necessary.
Old Jul 2, 2009 | 02:43 PM
talon90's Avatar
talon90
NCM Ambassador
I'm shocked but worse than that, I'm sorry for your trouble. It is a shame that they don't drill any longer as that is what will prevent the additional cracking and it also allows the epoxy to flow out in to the cracks at the edge. It wasn't Safelite that did my repair, it was a local glass place but the repair was almost flawless and it certainly didn't crack any more, nore did it become more visible.
I would never recommend this procedure if my experience had been like yours.
To Repair or replace?
