towing c6
Jul 6, 2009 | 12:46 AM
towing c6
can you tow a c6 rear wheels on the ground on a dolly?an automatic or a 6 speed?
Jul 6, 2009 | 12:57 AM
Jul 6, 2009 | 10:13 AM
Quote:
Originally Posted by
tonycorvettes
Don't know about an automatic but these are the words from the T56 manual.
Towing: Drive shaft MUST be disconnected vehicle is to be
towed. Failure to do so WILL result in internal
transmission damage.
Available at:
http://www.ttcautomotive.com/English...ice_Manual.pdf
Jul 6, 2009 | 11:32 AM
Jul 6, 2009 | 11:42 AM
you could put the rear on a "dolly"
Jul 6, 2009 | 01:06 PM
St. Jude Donor '09
CMY SIX
This would be my first thoughts if I absoloutly, positivley had to tow, otherwise a trailer would be the way to go and if you did use the dolly with the rear on it not sure you would have to much of the front air dam left, but this can easly be replaced or removed.
and good luck.
Jul 6, 2009 | 04:02 PM
St. Jude Donor '11-'12-'13-'14-'15
CMY SIX
I saw a Vette being towed this way and everytime the they hit a bump the nose scraped the pavement.
Jul 6, 2009 | 04:04 PM
AU N EGL
flat bed or trailer only
