LS3 Envy?
Old Jul 14, 2009 | 12:08 PM
  #161
Marina Blue's Avatar
Marina Blue
Originally Posted by LBear
It's silly that people think that GM lied or that the #'s were skewed. When something is SAE certified, it goes through some very, very strict testing. When SAE came out and said that the LS2 gets 400HP, that is a 100% fact.
Someone heard or read that the LS2 in Australia made 412HP. The reason why it made 412HP was because they MODIFIED IT, but it was for AUSTRALIAN USE only in the E-series HSV's.
So the facts got twisted and then the rumor circulated that the LS2 makes 410HP+ here in the states and in the Corvette. Which it does NOT. The LS2 in the Corvette makes 400HP from the factory.
The facts didn't get twisted in the way you are stating and the higher power number from Australia was not part of the basis for a higher rated LS2.
The LS2 was never officially certified, which allowed Chevy to play with the numbers. If the engine had originally been introduced in 2006, after their policy was to certify all new engines, it would have received a higher rating.
Old Jul 14, 2009 | 12:20 PM
  #162
Marina Blue
Originally Posted by '06 Quicksilver Z06
Take into account how they measure engine power in other areas of the world. They use DIN if memory serves me.
Also if I recall correctly, the LS2 is rated at somewhere around 412 DIN.
Wrong. The Australian improved LS2 rated 417 DIN, which converts to 412 original SAE net
Old Jul 14, 2009 | 12:37 PM
  #163
Marina Blue
For those involved in this thread, take the time to go back to my "LS2 Certified Horsepower--For LS2 Guys" thread at the following address: http://forums.corvetteforum.com/c6-c...-ls2-guys.html
If you read this before, read it again, there are quite a few changes. Also read the documentation--it's very important in understanding where the information came from.
When you are done, choose to believe what you want, but if you think the LS2 only makes 395 or 400 horsepower, you’re in a state of denial. Readers of this thread should make a judgement on its content and then interpret as they wish.
Old Jul 14, 2009 | 01:00 PM
  #164
AirBusPilot's Avatar
AirBusPilot
When you are done, choose to believe what you want, but if you think the LS2 only makes 395 or 400 horsepower you’re in a state of denial. Readers of this thread should make a judgement on its content and then interpreting as they wish.
I think reading it once was one too many times. I've never seen so much crap compressed and distorted to support a position that is a lie. However, I think you have a bright future working for any political campaign.
Old Jul 14, 2009 | 01:03 PM
  #165
StoplightWarrior's Avatar
StoplightWarrior
Originally Posted by MLCZ51
my Z51 LS2 with vararam and headers with tune EATS ls3's...cost me about 2k for the mods.
Ok, but my LS3 with Vararam, bolt ons, and tune would EAT your ls2.
stock for stock, the ls3 > ls2
Old Jul 14, 2009 | 01:08 PM
  #166
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
When you are done, choose to believe what you want, but if you think the LS2 only makes 395 or 400 horsepower you?re in a state of denial. Readers of this thread should make a judgement on its content and then interpreting as they wish.
You mentoin your "sources" inside GM who have provided you with this information.
An open question to you or any other active member here.
Has anyone else received this information from your named source and your other two "unnamed" sources.
Can you show us where anyone else has claimed to have spoken to someone at the plant and heard the same thing. And I don't mean referances to the post of the original person who hatched this whole thing. Don't bother referring to his posts from back when. We both know who I'm talking about.
Who in here, aside from the person who initially hatched this whole farce, has claimed to have heard the same thing from GM that you say they, your "named source" and two unnamed sources told you?
Old Jul 14, 2009 | 01:32 PM
  #167
da-googoo-man's Avatar
da-googoo-man
This is a cool thread and for many reasons. If you know how to drive your car on the track then the 30HP difference could create a slight advantage but if the car is used as a DD then no need for mods to capture the extra ponies. If you track your car and know how to drive you can basically match the LS3 performance numbers with an LS2.
Learning how to handle the vehicle will compensate for having even fifty less HP when in the hands of a skilled driver. I say spend the money on learning how to drive the car the benefits of which will outlast the cost of any mods and will probably amount to the same expense. OR as other members have pointed out… simply help the car breathe a bit better and tune to liking. Just my .02
Me: 2006 with Z51 “option” + lots of track time =
Old Jul 14, 2009 | 01:48 PM
  #168
'06 Quicksilver Z06
Default S
So now its 412 hp. A minute ago it was 405-408. Now its 412. If we wait long enough, I suspect that it will eventually become just as powerful as the LS3.
I consider you a friend. This has gone on for long enough.
Old Jul 14, 2009 | 01:56 PM
  #169
AirBusPilot
Curious, on one hand you argue that the actual performance difference published by gm show less than a 30 something hp difference. Then you argue that chassis dyno numbers that support the factory hp ratings are misleading because the LS2 has a transmission that robs more hp than the LS3. Do you see the contradiction there?
And, why didn't gm publish improved 1/4 and 0-60 times for the Z06 when it has used both transmissions? Why isn't it quicker with the 6060? Why is there NO difference in dyno numbers??
Old Jul 14, 2009 | 01:58 PM
  #170
Marina Blue
So now its 412hp. A minute ago it was 405-408. Now is412. If we wait long enough, I suspect that it will eventually become just as powerful as the LS3.
Read the thread. 412 was the Net rating of the enhanced Australian LS2. 405 to 408 is the Corvette LS2.
Old Jul 14, 2009 | 02:07 PM
  #171
Marina Blue
Yo
Can you show us where anyone else has claimed to have spoken to someone at the plant and heard the same hing. And I don't mean referances to the post of the original person who hatched this whole thing. Don't bother referring to his posts from back when. We both know who I'm talking about.
Who in here, aside from the person who initially hatched this whole farce has claimed to have heard the same thing from GM that you say they, your "named source" and two unnamed sources told you?
As mentioned before, I will not reveal that information.
You have thrown around words like farce and BS quite a bit in this thread. I won't use them, but do call horse manure (more familiar with that) on much of what has been said here--and it is not coming from me. The BS has gotten so deep that I have to put boots on before entering the computer room.
Old Jul 14, 2009 | 02:09 PM
  #172
AirBusPilot
Good questions.
Can't answer everything...ask GM.
Gm isn't stating that there is anything wrong with the HP ratings of either engine.
Since the Z06 has shown no performance change and no one has shown dyno number differences between the two different transmissions you can conclude that there isn't a difference in power loss.
That leaves chassis dyno averages. Since it's fairly well established that the chassis dyno differences between the LS2 and 3 support the published and certified gm figures, you can draw the conclusion that both engine's published dyno figures are accurate.
Old Jul 14, 2009 | 02:12 PM
  #173
Marina Blue
You voiced your position many times before...I'm OK with that.
Old Jul 14, 2009 | 02:14 PM
  #174
Marina Blue
Sounds logical, but there is one big problem with that--I have been told otherwise by people in a much better position than your own.
When the Z06 with LS7 engine was introduced for the 2006 model year, an improved T-56 transmission went into the package, which may have made it closer to the newer TR-6060 in performance. I am not able to reference this, but I'm pretty sure I remember smoothing of the gears for better shifting and other enhancements in that transmission.
As far as chassis dyno averages are concerned, we don't really know the true averages as cars on the low end are less likely to be reported...especially with the hype the new LS3 created. Also, there is at least a 25 to 27 HP variance between chassis dyno numbers--how accurate is that? Using chassis dyno figures to back calculate true engine (flywheel) horsepower is unreliable at best. GM's own performance figures are a much better measure for comparison and that does not include either magazine or "The List" times from Corvette Forum, which both are subject to many variables and in the case of "The List" entrants being unverifiable for factory stock status.
Old Jul 14, 2009 | 02:19 PM
  #175
djfullshred's Avatar
djfullshred
IMO, this is such a pointless thing to care about.
Either you don't race (like myself), so it doesn't matter that the newer model down the line has a bump in horsepower...
or you do race, and if so, 30 more horsepower is probably well short of your target, considering there are a lot of modded C6s out there putting out much bigger horsepower than 436.
Old Jul 14, 2009 | 02:27 PM
  #176
AirBusPilot
Ok. I see it's boiled down to logic/factual data versus hearsay/no data. Not trying to be an *** (now, lol). But that's just what it boils down too.
Old Jul 14, 2009 | 02:30 PM
  #177
AirBusPilot
Ok, now I'm going to go melt the tires off my LS3. No, I'm not going to get on it... it's so hot here that the road surface temp is approaching that of a sun going supernova.
To LS3 Envy?
Old Jul 14, 2009 | 02:34 PM
  #178
Marina Blue
As I stated, your questions are good ones. The thing is, my sources are the best and there is a lot of supporting information. For you it is hearsay, but for me it is first hand. Sorry I can't give you more than that without violating private information.
Old Jul 14, 2009 | 02:39 PM
  #179
Marina Blue
True, but I previously put a lot of work into this and now got caught up in this thread by trying to help the original poster.
Did you ever fix that noisy "B" pillar. Mine came out great, thanks to your thread.
Old Jul 14, 2009 | 02:47 PM
  #180
JDC1999's Avatar
JDC1999
I'm just happy I've got a convertible vette!!!!
