Service column lock.....again!
#41
I have been currently having this problem with mine, there are 2 ways to get it started.
1. If the message center says “service column lock” I can usually take the load off the wheel (and locking pin) and then push the start button at the same time and the car will start.
2. Sometimes the wheel does not lock and the car does not start, I get no message on the information center and the battery voltage is fine. When this happens I disconnect the positive battery cable, touch it to the negative cable for 10 second, then reconnect it. This clears out / resets everything and the car starts. You may need to cycle the switch twice to get it to start, but usually when you reconnect the battery, you hear the lock motor cycle and the car will start on the first try.
THANK YOU very much for this post !
#42
#43
Hello everyone.
For the 2nd time in 5 months, I`m having to tow my vette into a dealer for column lock issues. 52,000 fairly problem free miles and now this.
So I suppose I have to fork over money for another towing bill.
Yesterday it was running fine and today this. Seems quite sudden. Is there anything I can check before having it towed. Battery is new and on charger.
