The ABS plastic hatch pull down handle cracked near the right screw mounting hole. The design was not very robust. I repaired by removing the original handle and replaced with a 2" wide black leather strap made from thick belt leather. I put a radius on both ends of the "cut to length" leather strap and dyed the cut ends of the leather strap with a black leather dye. I used the original mounting screws, but I added 1" diameter black nylon washers on the screws to help distribute the clamping load. The modification is more robust than the original plastic handle and I think it also looks a little better. The black leather pull down strap blends in with the inner hatch panel. I allowed for a slight downward bow in the leather strap to provide for additional finger clearance. The new leather pull down strap also has a more comfortable feel than that of the ABS plastic handle, since the leather is soft and flexible.
Broken OEM Handle - Crack in ABS Plastic Handle at Red Arrow
New Black Leather Pull Down Strap
My 09 didn't have the handle. I added one, but GM does not have the underneath mounting hardware in place that is there with a factory installed handle. I drilled the 2 holes in the surround, threaded the surround material to hold screw, and used JB Weld epoxy to hold the 2 screws in place. It works, but no future tightening of the screws once epoxy set up.
Here are photos of my 07 with factory handle. http://picasaweb.google.com/Karman19...Iuczbmgx6CVMw#
The threaded fitting in the surround I could not find. Home Depot had some sort of fitting that is too tall to fit in the surround.
My 2006 had the handle and I liked it, put a piece of white tape on the handle so it was easier to find in dim light.
My 2009 does not have the handle, and I missed it. Using the center latch as a pull-down was less comfortable, and I had a faint fear that I'd close the hatch with my finger still in the hook.
I painted the rear edge of the hook with white paint, and also put a couple of strips of white tape alongside the hook so it is easier to locate in the dark, similar to what I did on the 2006.
After 6k miles with the new system, I'm comfortable with it and don't miss the handle.
Different strokes...
