Does jacking up car affect suspension/alignment??
Old Aug 22, 2009 | 01:13 PM
Bat Man's Avatar
Bat Man
Default Does jacking up car affect suspension/alignment??
Lets say you are lifting it up 1 wheel at a time. Does this affect the cars alignment at all? Or flex the chasis?
Old Aug 22, 2009 | 01:17 PM
Mark VerMurlen's Avatar
Mark VerMurlen
I shouldn't affect the alignment when you put it back down and let the suspension settle. The chassis will surely flex when one wheel is lifted, but that won't do any harm to the car.
- Mark
Old Aug 22, 2009 | 01:32 PM
CQRT's Avatar
CQRT
Sure - lifting each side can affect that corner because of the weight of the wheel/tire and suspension . . but it'll return to normal upon driving . . the chassis does not flex like the old Corvettes did . .I remember having to open the doors on my C3's so they wouldn't bind up when it was lifted although I'm not sure that wasn't more mistique than fact.
Is there an underlying issue you're trying to address?? A few more details might help . . .
Old Aug 22, 2009 | 01:35 PM
orca1946's Avatar
orca1946
Need more info on the question. Ae you trying to align the car ? Are you asking if it changes it in the long run ?
Old Aug 22, 2009 | 01:45 PM
User 81424's Avatar
User 81424
No and no.
Old Aug 22, 2009 | 02:20 PM
quicksilver436's Avatar
quicksilver436
If I may tag along with the original question....I want to jack the vette one rear wheel at a time using a floor jack. Is the best jacking point at the nearest puck or behind the wheel per the manual. I don't think I have seen anything addressing lifting one corner at a time.
Thank you.......
Old Aug 22, 2009 | 02:44 PM
STEVE MC's Avatar
STEVE MC
Thank you.......
If your jacking one wheel at a time use the jacking puck for that quarter to lift it up the car a few inches for tire removal. If you are raising it higher than a few inches then the whole rear or front should be lifted from the recomended jacking points under the chasis and then supported on both sides with jack stands and pucks.
Old Aug 22, 2009 | 02:48 PM
Wayne O's Avatar
Wayne O
CF Senior Member
There's nothing wrong with lifting one wheel/corner at a time but you'd be better off buying and using an adaptor beam to use with a floor jack. With an adaptor beam you can lift using the preferred lifting points and you'll be able to lift the front or rear at once. Lifting one corner is IMO best done using pucks but if you're careful it can be done without pucks and without damaging the car.
Here's a somewhat related thread that may help:
http://forums.corvetteforum.com/show....php?t=1301555
Old Aug 22, 2009 | 03:08 PM
quicksilver436
Thanks for the info and advice.
Old Aug 22, 2009 | 03:21 PM
JRHAWK9's Avatar
JRHAWK9
personally, I wouldn't jack the car up on a body mount just to lift one wheel off the ground. This means it requires you to unload the full suspension before the wheel gets off the ground. You could possibly have to raise that one corner of the car a good 6" or more before the wheel comes off the ground. In cases like this I always raise the one corner by the lower control arm or something sufficient right behind the wheel. I just put a piece of wood between the jack and the contact point. This allows the suspension to stay loaded which dramatically decreases the height you need to raise it before the wheel comes off the ground.
Old Aug 22, 2009 | 03:45 PM
GCD1962's Avatar
GCD1962
If it did I wouldn't want to drive the car.
To Does jacking up car affect suspension/alignment??
