Patch Firestone Runflats ?
Old Sep 1, 2009 | 12:39 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by sxeC6
Firestone is part of Bridgestone.
Since you carry an inflator pump, why not buy a plug kit to go with it. If the tire can be plugged, do it yourself. If the tire is damaged beyond plugging, you're screwed no matter what brand tire you have.
I do carry a plug kit too, but consider it only a short term fix so I can get someplace for a proper repair (probably a new tire).
Old Sep 1, 2009 | 12:42 PM
Gearhead Jim
St. Jude Donor '13
Originally Posted by AORoads
as far as Firestone runflats being too conservative or not enough warranty or whatever, I'd say klaus96's list of items that would knock out a Firestone tire will also knock out a Goodyear or Michelin runflat tire.
for instance, if there's noticeable deterioration on the outside or inside of a tire due to a "flat" and being run in the runflat condition, your tire is toast no matter who makes it.
That is correct, but the Goodyear list of things that require a new tire does not include "the tire was operated with an inflation pressure of less than 15 psi". Goodyear allows repair based on tire condition, Firestone just says "toss it out".
We're waiting to see about Michelin.
Old Sep 1, 2009 | 03:19 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I agree that a plug is a quick fix only until you can get it properly repaired, but it may save the tire if you get a low pressure warning as happened to me went I had my C5.
I suspect that Firestone's sidewalls are not as stiff as GY's. Consequently, they give a better ride at the expense of possible damaging heat build up from running at low to no pressure. Michelin may have solved the problem with a more expensive construction method. So it becomes a matter of choice.
Old Sep 1, 2009 | 08:25 PM
phileaglesfan's Avatar
phileaglesfan
The fact is that due to the Corvette's somewhat unique dual sizes you will always run the risk of being stuck out there in the middle of no where for days. It doesn't matter if it is run flat or not. However Firestone says their tire is no good if used while the pressure is below 15psi so that increases your chances of being stuck over say Michelin or Goodyear.
I usually buy Michelins for my cars. Depending on how/where you drive the Mich ZP A/S tire might be an option which is pretty close in price to Firestone. Yeah people wonder why put an A/S tire on a Vette but if you live in higher altitudes or cold climates they may help someday. Also the real world driving performance difference is pretty close.
Old Sep 2, 2009 | 11:31 AM
Rich Farr's Avatar
Rich Farr
Default Firestones Vastly Superior to Goodyears
I have had 3 sets of Goodyears runflats on C6 and C5 Vettes and one set of Michelin runflats and one set of Firestone runflats. The Goodyears were all terrible. The Firestones were vastly better for smooth ride, noise and traction. I consider the need to pro-rate the tire if it goes below 15 psi an acceptable compromise.
I had a nail one of the Goodyears, but did not lose any air. The tire was patched by a Goodyear dealer.
Old Sep 2, 2009 | 12:26 PM
wratran's Avatar
wratran
i have the firestone for over 10K miles. I have 2 plugs on one of the tires with no problems. I just buy a plug kit from walmart...and it held up since then....
I think it's another way for them to make money.
Old Sep 2, 2009 | 12:39 PM
Gearhead Jim
St. Jude Donor '13
Wolfdogs just retired from a long career as a tire expert, you might wish to get his opinion on plugging tires as compared to the mushroom patch from inside...
Old Aug 20, 2011 | 06:26 PM
rayk's Avatar
rayk
This is from the Firestone RFT Q&A.
Is it possible to repair a Run-Flat tire that has been punctured?It depends on how far and at what speed the car was driven after the puncture was sustained. Repair is possible only if deemed so by the tire sales store.
Preconditions include a puncture of less than 6mm for both side-reinforced type and support-ring type Run-Flat tires, plus minimal damage to the support ring in case of the latter.
However, it is strongly recommended that the tire is replaced as its durability will have been weakened after being repaired.
I would buy a new tire.
Old Aug 20, 2011 | 11:34 PM
cmdrzero's Avatar
cmdrzero
Default Plug.
I plugged my Firestone about 10,000 ago. Tread puncture by sharp bolt. S9o far so good. It should test my driving prowess if it blows over 100 mph. What a car! What a country!
Old Aug 20, 2011 | 11:59 PM
crusher1's Avatar
crusher1
I just had 2 nails in the same Original Goodyear tire patched from the inside 2 days ago...So far no problems
