Radar detector
The last road trip I was on revealed the LEO's using 45 degree to the center side of the road with fast off/on radar tactics in both Florida and Georgia in which case just about any detector would be so-so.
No I really don't speed much but I do like to know when I have company, it tends to keep ME honest.
Never buy a Bell
Traffic radar is a very common enforcement device. Many departments install one in every car, and the officers drive with them on most of the time. That makes speeders an easy catch if they are inattentive.
Now having a detector helps a little, but not that much. In a growing number of states having a radar/lidar detector is against state statute. Having a Corvette is a big plus as far as radar operation is concerned. The circuits in the radar generally are looking for a) the most powerful reflected signal, or b) the highest frequency returned indicating the fastest vehicle in the beam. The new radar units are really sophisticated, having multiple filters to allow the selection of the car ahead, car behind, oncoming car or car that has passed. I used a two antenna four way unit for a number of years and the killer mode was to wait to track cars approaching fast from the rear. It was like shooting fish in a barrel using an unmarked car.
Another problem with a detector in a Corvette is that to gain the maximum advantage of time and distance from a radar unit the detector should be mounted as high on the car as possible. Radar beams spread out from the antenna at between 18 degrees and 12 degrees in a cone shape. That’s a lot of spread so most enforcement takes place “close up and personal”. Motorcycle officers particularly like to find a great place and “cherry pick” the fast ones. Up to around 10 MPH over the speed limit MIGHT slide you buy, but not always. If you are in a school zone or construction zone, just follow the speed signs and be safe.
Last piece of advice – if you do buy/have/use a detector, you must ALWLAYS obey each and every alert, even if it seems that there could not be an officer in miles. This is the ONLY way you can reduce your risk of getting stopped. And don’t forget attitude. I have issued many tickets to those who chose to “flunk the attitude test”, arguing about speed or whether I should have been “out catching real criminals”. That resulted in the same time honored phrase “Press hard, sir, there are five copies. You court date is on the back – have a nice day”.
I will entertain questions about radar and lidar at iwallace@columbus.rr.com
Drive safe, fellow Corvette owners!
One thing the V1 picks up a LOT is junk radar detectors on the K band, I've positively IDed users of junk detectors before (by watching what cars are in front/back/side of me and how my V1's arrows/strength look as i approach other cars, then I look on their windshield, and lo and behold is some crappy radar detector).
http://www.youtube.com/watch?v=yr6aB...layer_embedded
