Auto window function @ exit...HELP!
Old Sep 26, 2009 | 06:46 PM
KTVette's Avatar
KTVette
Default Auto window function @ exit...HELP!
Hail to all those with abundant C6 knowledge!
All of a sudden when I exit my car the window when I close the door, both driver and passenger side, do not go back up!!!
Can anyone tell me if this is common, and is the fix as easy as a fuse?
So any ideas would be appreciated, thanks.
I'll sit here and wait for the brilliant help!
Old Sep 26, 2009 | 06:56 PM
cclive's Avatar
cclive
Need to re-index the windows. Get in car; close doors. Push window switches up. Hold for three or four seconds after window stops. Then without putting windows down, push both buttons up and hold again for a few seconds.
Old Sep 26, 2009 | 07:11 PM
KTVette's Avatar
KTVette
You ROCK! Fixed. Only concern now is battery did not die, but when i got back in my car this afternoon all tire gauges read zero. Hmmmm, what's going on?????
Old Sep 26, 2009 | 07:12 PM
CQRT's Avatar
CQRT
Have you replaced your battery recently -- or should you ? Those are generally the circumstances where you need to re-index the windows . . .
Old Sep 26, 2009 | 07:29 PM
VET4LES's Avatar
VET4LES
Old Sep 30, 2009 | 08:45 AM
VetteFreak74's Avatar
VetteFreak74
Thanks so much. I just got back from Iraq and was assuming that replacing the battery was somehow involved. If only all of life's problems could be re-indexed Once again, I am humbled by the collective sage wisdom of our forum members.
Old Sep 30, 2009 | 09:04 AM
Vette_DD's Avatar
Vette_DD
Sounds like your battery won't last much longer. Any time you disconnect the battery for more than a few seconds, you will have to reset the window indexing as indicated above.
99% of the time, that's the only thing you'll have to reset.
To Auto window function @ exit...HELP!
