Check Engine Light
Old Sep 27, 2009 | 03:36 AM
VinnyG's Avatar
VinnyG
Default Check Engine Light
Does anybody know the procedure for restting the Check Engine Light?
Thanks,
Vinny
Old Sep 27, 2009 | 07:43 AM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
With the Corvette tax and all, I'm sure it involves a Tech II.
Old Sep 27, 2009 | 07:56 AM
RadarP3C's Avatar
RadarP3C
No need for a Tech ll.
Most scanners have the capability to reset a CEL. If you don't have one, or have a friend that does, you may be able to have someone at AutoZone reset it for you with their scanner. But note that some AutoZone's stick to their policy of not resetting CEL's.
You can also buy a cheap scanner for under $60.00
Old Sep 27, 2009 | 08:05 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
One trick that works for me is to disconnect the negative side of the battery for 30 seconds. I never had a problem with my 08 Vert but I did with a 03 Silverado with 240,000 miles. The Oxygen sensor was bad and I felt no need to replace it. Anyway, every 4 or 5 days I had to disconnect the battery to get it to go away. They only pain was I had to also re-set the clock. ...With the Vette, I imagine you also have to re-index the windows. Good Luck
Old Sep 27, 2009 | 08:17 AM
LMB-C6's Avatar
LMB-C6
Depending on what conditions set it, it may automatically go away after a certain number of restarts, but more than likely you will need to have it reset using a scan tool. If it were me, I'd want to know what it's complaining about - go to one of the auto parts stores and see if they can read the code for you....and maybe have them reset it.
Old Sep 27, 2009 | 08:31 AM
MARSC6's Avatar
MARSC6
Disconnecting the battery does work but you should probably at least go to an Autozone and get a free scan to find out the problem.
Old Sep 27, 2009 | 09:00 AM
SlideRulz's Avatar
SlideRulz
I did this last week, it's the easiest way to clear the light.
Go to the fuse box under the passenger floor board and pull the ECM fuse (check your owners manual for diagram) for a few minutes then reinstall and start your car. Light should be off.
Old Sep 27, 2009 | 09:27 AM
knick's Avatar
knick
Old Sep 27, 2009 | 09:40 AM
VinnyG's Avatar
VinnyG
Thanks for all of your input. I will have it checked with a scanner. I had just finished installing a new and improved exhaust controller when this occured. I disconnected the controller after the light came on but the CEL is still on. However, I didn't drive the car after that to see if it would go out.
Old Sep 27, 2009 | 10:24 AM
Wayne88's Avatar
Wayne88
It worked for me.
Old Sep 27, 2009 | 11:33 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
I see you don't live far from me so if you want bring it over and I'll reset it with my scanner and check for codes. I sent you a PM
Old Nov 4, 2009 | 02:01 PM
vettemann62's Avatar
vettemann62
EXCELLENT SUGGESTION WORKED GREAT! Leave the fuse pulled for about 10-15 minutes.
Old Nov 4, 2009 | 02:30 PM
Charley Hoyt's Avatar
Charley Hoyt
The Autozone near me no longer lets you use their scanners. I tried it last night.
Old Nov 4, 2009 | 02:35 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
There is a problem, pull the code.
Disconnecting battery just eliminates te SES light. It will return.
The exhaust controller is a problem.
Not sure how you're pulling power or from where but I'm betting it's the problem.
Old Nov 4, 2009 | 02:57 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Thanks,
Vinny
Finding the cause of the check engine light is usually the best course of action for resetting it. You will need to pull the codes with an OBDII code reader. One of the most common causes is a gas cap that was not properly seated after filling up for example. Once it is reseated and the car passes several ignition cycles it will turn out the light. Resetting the light without finding the cause of the problem will only result in the light coming back on.
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
You da man brother !!
To Check Engine Light
