Almost lost it last night! I have an 07 vert with the original Z51 tires still on it. When I left work the temperature was around 60 degrees. I took a slight turn (no more than 45% bend in the road) I have taken 100 times before and when I got on the throttle the rear started to slip and scared the you know what out of me. I had forgotten how bad those tires are when the temperature drops. The real cold has not even hit yet.
most of the posts are about 40 degrees, and less. but that doesn't mean that the road is that cold; sometimes even at 60 outside, the road surface may be colder.
recall: if you go down I think it's 5+ ft. below the surface, the earth temp is a constant 50-55 degrees (the source for geothermal heating/cooling devices). add in a little moisture on the road surface due to cooler weather condensation, and you have your occurrence.
let's be careful out there....glad you caught the car.
One other thought - leave the electronic nannies ON - they're there to save your butt. We don't want that picture thread where everyone is thinking "Oh My Gosh - look at that"................
Even when the Traction Control is on, you will side slip a little when the tires spin. Below 50F on the OEM tires, you need to be careful when accelerating away from a traffic light.
Low performance drivers with high performance cars blaming cold for their mishaps.
Peace, out.
Have you driven a Corvette with Goodyear Supercar tires? They are a summer tire and get real greasy in cold weather.
PS-I've been driving high performance cars starting inthe 1960's(drivers license since 1956). My 09 Z06 has the supercar tires and they are scary in cold weather, even with the nanny turned on.
As long as we remember that the tires aren't as good in cold, though it may be a dry cold, you can adjust yourself and still enjoy your Corvette, (a lot too).
Drove one this morning...temps in the 30's...no worries!
This one is a 2009 CG convertible; yes, with Z-51 and Supercar tires! This is my 5th Corvette, and I, too, have lots of experience with high performance automoboles plus professional training. In my experience, absent US Baldies, tires are never the cause of problems that cannot be managed.
Your car should have A/S tires since the month of september. You are not to far for winter tires now you know. snow flakes are around the corner.
I will tell you this:
The tires will be hot by the time the oil is hot enough to do this kind of stuff. That is, it takes the tires only a few minutes of driving to come up to temperature, whereas it takes the oil a good 10 minutes before the oil is hot enough for spirited driving.
Seriously. I've been autocrossing for 10 years and am pretty good with car control, but those things surprised me a few times in cooler weather.
Yesterday at noon, after driving about 15 miles, everything was nicely warmed up and the OAT gage said 55'F. Nice sunny day, so the pavement wouldn't be too cold. Z51 Supercar tires.
Trying a quick start produced big black stripes and some tail wagging, but not much acceleration, happens every year. I call it the "Fall Surprise".
I've driven Supercar tires down into the 20's, but you lose a LOT of grip any time it's cool enough to wear a jacket. My Goodyear All Season runflats are MUCH better in cool weather, but limited to only 160 mph.
