I still have the K&N on mine and very little difference if you can even notice it. My intention was not to increase hp/torque though it was just to get more cold air in. If you want toque,hp you need to throw in a lot more in.
1. which cold air intake increases HP by the most? K&N?
2. I know cold air intake increase hp, but does it also increase torque also?
3. people who installed an intake already, do you guys notice a difference? is it worth it?
I like the Vararam, It is good for few HP (5-10). The way its designed, the faster your going the more air your forcing in. It does make a slight increase in fuel milage. 1.5 mpg on average at steady 75-80 mph crusing. So is it worth it??? Hell Yes, What you tell people is its now making 35 HP and 25 FT/LBs more at the wheels, and it will run 10s in the Quarter mile all day long.... not bad for just a CAI
Read most of the CAI ads with at least an open mind, beware of "advertising speak".
CAI stands for Cold Air Intake and unless the so called CAI makes some provision (A cut shroud or ducting to the filter) for getting fresh air to the filter it's not a CAI, just a filter/filter box change. The replacement filter may flow easier than the stock filter but it's not a CAI.
I put a Hurricane on mine, mostly for the look (carbon Fiber). But it does have crisper throttle response now. I do not believe any of the claims on any of these. The only real way would be a before and after Dyno on your car. However anytime you can shoot a cooler air-fuel mixture into a hot engine you will increase HP. And sucking HOT engine compartment air into the engine definitely will not increase HP.
Just remember that a CAI can also be a CWI - as in Cold Water Intake. There are reports on this forum of CAI - induced hydraulic lock and subsequent "broken motor" after a significant amount of water was ingested by the CAI. Rare - but still a risk. Not worth it to me - stock works fine.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Some good unbias answers here.
Cold air is good, but most of the so-called CAI's....are not. I installed one of the so-called CAI's on my car and only lost 3 MPG. I felt nothing in the SOTP, but I wasn't really expecting too. Real HP is expensive.
Larry
For the Hurricane to ingest water you would really have to drive through (and scoop up) water. It has two scoops on the top of the shroud, which is not inline with the entry. I think you would have to have the front of the car submerged to suck in any water.
The air intake is more about looks until you do headers, cam and catback then as a combo you get more out of it. With that being stated I put on an Airaid as I did not like the look of the 09 stockers silencer
I installed a vararam on my 07 A6 with Z51 package. I noticed a difference. Was able to run back to back 12.4's at 118mph a couple of days ago on a other wise bone stock car, not even a tune. IMHO it is a great mod for the money. Oh I get 28-32 mpg on the freeway all day long.
If your not cutting the shroud its not a CAI, the air the new filter will be drawing in the same temp air the factory unit does....
You might want to check out some temp. test I did on the factory LS3 unit...
Notice that while the K&N filter passes more air, more fine dust passes also! This is backed up by the oil aficionados who routinely report their oil analysis tests on forums like bobistheoilguy.com.
"Better" flowing filters show less filtration, and more dirt in oil analysis tests. Period.
I'm looking if there is a best CAI mod. There is some "zip-tie" mod for the LS3 C6's I'm trying to find. But I will not use less than a Wix air filter on my vette.
If you read the K&N ads carefully you'll see that they DO NOT advertise their filters or aircharger systems for the C6 as CAI. A K&N filter or Aircharger is NOT a CAI.
Any CAI should be followed by a tune to get the full effect of more air. The more air you let in the more fuel you can burn. To do this you should have the car tuned. I know for a lot of you it's a warranty issue and I understand that but my car was past the warrant stage so I installed a Vararam and had the car tuned and picked up over 50HP
Personally, I think they are unrelated. Today's electronic fuel injection systems are able to compensate for the slight change in air volume allowed by different intakes. Yes, you'll get more power with a tune. But get a tune without a CAI and you'll get more power anyway.
Intakes are not as magic as some would have you think. A filter has a flow rating. In most cases, the flow rating of any filter is greater than the flow demand of the engine - meaing that you are already getting all the air that engine requires.
As some have stated above, the benefit comes when you are ingesting colder air from outside the engine compartment.
Also - beware of "dyno" claims on CAI's. Every dyno run I've ever seen is done with the hood up and a huge fan blowing air over the car. What that tells me is that you are comparing before and after runs both with the benefit of cooler air than on the road where the hood is closed.
Understanding the dynamics of how an engine works helps debunk many of the myths of intakes. I believe that a true COLD AIR intake can increase horsepower, but most of the claims are not very believable.
I feel there's no question a true, bottom-feeding cold air intake is beneficial. That said an after market cold air intake on its own will not make a noticeable (seat-of-the-pants) difference. IMO a cold air intake should be thought of as but one component in your overall modification plan.
There are several decent and popular cold air intakes on the market (such as Vararam and the Callaway Honker). My preference was the Lingenfelter high-flow intake. IMO the name "Lingenfelter" is synonymous with Corvette performance engineering and quality. I've been very pleased with my LPE intake!
