another button question
Old Nov 5, 2009 | 05:38 PM
MRBILL1957's Avatar
MRBILL1957
Default another button question
There are butttons or levers on each side of the car down by the sill plate. What are these for.
Old Nov 5, 2009 | 05:39 PM
John_Syb's Avatar
John_Syb
They open the doors in the event that you lose electrical power
Old Nov 5, 2009 | 05:40 PM
C6NRED's Avatar
C6NRED
They open your doors in case of an electrical failure.........RYOM
Old Nov 5, 2009 | 05:43 PM
xcutter's Avatar
xcutter
CF Senior Member
I thought it was to activate the ejector seat. Then I read the owners manual. It was very helpful
Old Nov 5, 2009 | 05:44 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As noted, these are mechanical release levers for the doors (emergency release) in the event of a power failure.
Covered in your owners manual.
Old Nov 5, 2009 | 05:45 PM
Wayne O's Avatar
Wayne O
CF Senior Member
With all due respect...read your owner's manual. It contains a wealth of valuable information.
Old Nov 5, 2009 | 05:48 PM
StanNH's Avatar
StanNH
Emergency tire inflators. If you keep pumping them real hard, your tires will inflate.
Old Nov 5, 2009 | 05:51 PM
talon90's Avatar
talon90
NCM Ambassador
You are so bad.
Old Nov 5, 2009 | 05:59 PM
StanNH's Avatar
StanNH
Originally Posted by talon90
You are so bad.
Sorry Paul. Sometimes I just can't stop myself.
Old Nov 5, 2009 | 06:08 PM
acejack's Avatar
acejack
Old Nov 5, 2009 | 06:17 PM
haljensen's Avatar
haljensen
For use only when the Computer Controlled Electronic inflators for the runflats doesn't work.
You know; When you bring up tire pressure on the DIC and regardless of what numbers you enter the computer won't inflate the tires to the desired pressure. I hate it when that happens!
Old Nov 5, 2009 | 08:47 PM
Swiftrider08's Avatar
Swiftrider08
Those handles/cables are so you can get OUT of the car with no power, but you do also know that there is a cable on the drivers side wheel well in the rear hatch area that allows you to get IN the car if you have no power, right? You use your key to open the rear hatch, key switch/slot is just above the rear license plate, and then you pull the cable to open the drivers side door.
Old Nov 5, 2009 | 08:55 PM
Vette Suspension's Avatar
Vette Suspension
What a great option that would be. Imagine the possibilities.
Old Nov 5, 2009 | 08:56 PM
-CM-'s Avatar
-CM-
The door releases are also useful when you don't get the door quite closed, but you're already in gear and rolling. You can't use the normal button to open the door unless the (automatic) tranny is in park, but you can lift the lever to open the door.
To another button question
