Replacing coolant?
Old Nov 14, 2009 | 08:24 AM
Dans C6's Avatar
Dans C6
Default Replacing coolant?
I have an 05, and come spring I'll be changing the coolant. So I was wondering if anybody did it themselves or did they go to the dealer? Any problems or tips I should know? Done a little research on this, but I figured this is the place for the best answers.
Old Nov 14, 2009 | 08:35 AM
Justasheet's Avatar
Justasheet
I did mine when I changed my t-stat to 160 deg. model.
The drain is on the bottom of the rad. on the pass. side. Just give her a twist. If you want to drain the block, you may want to just loosen the 2 screws that hold the therm. in place and it will all rush out.
Filling was the diff. part for me. There is no rad. fill, just the overflow so, you fill it and it's tough with the air inside. It eventually filled but keep an eye on the temp. guage. You may have to do it a little at a time.
There were many suggestions on how to avoid this problem but I'm not that advanced. Just have patience and it will go fine.
I used the recommended Dexcool Prestone full strength (not the 50/50 mix) and it used 1 gal. exactly and one gallon of distilled water.
Have fun with it.
Jeff
Old Nov 14, 2009 | 08:42 AM
Dans C6's Avatar
Dans C6
Just concerned about taking it to the dealer for this. Don't want them making a mistake or something else bad to happen.
Old Nov 14, 2009 | 08:45 AM
not08crmanymore's Avatar
not08crmanymore
I thought the coolant they use is good for 100,000k??
Old Nov 14, 2009 | 08:47 AM
Justasheet's Avatar
Justasheet
I think it's 5 years or 100k. His is an 05. I had to change mine for the t-stat but I would have anyhow, mine is an 05 too.
Old Nov 14, 2009 | 08:51 AM
Dans C6's Avatar
Dans C6
manual says 5 year or 150,000 miles or so, whatever come first. I have 11,030 miles on it. Build date 12/04. So I figured come spring better change it.
Old Nov 14, 2009 | 08:56 AM
Justasheet's Avatar
Justasheet
That's low mileage, I'm jealous. Do a search for the thread with step by step instructions with pics. I tried to find it for you but couldn't. That's what I used and it made it simple. This forum is the BEST!!!
Jeff
Old Nov 14, 2009 | 09:01 AM
zero5see6's Avatar
zero5see6
I have an 05 and changed mine last spring. Very easy to do, just takes time. I premixed Dexcool with distilled water in a pitcher 50/50 and then poured slowly when filling. I drained and refilled four times. Not sure if this is needed, but wanted to get as much of the old coolant out as possible.
Old Nov 14, 2009 | 10:08 AM
C8-Vette's Avatar
C8-Vette
When changing the Dexcool make sure you capture the old stuff and dispose of it properly. Don't let it run down the driveway into the street. Due to it's sweet taste, dogs, cats, birds suck it up and die a painful horrible death.
To Replacing coolant?
