The only thing I can think is to remove the door panel and make sure that everything moves freely. Be careful... dont get your fingers pinched.
While in there, I might also might put a meter on the motor to see what kind of voltage was getting to it.
If the window was replaced it is possible that it was a little thicker and the weather stripping is pushing harder on it causing the window to be slower.
If it your window regulator it'll cost a few hundred dollars to replace........$678.45 for the part, I can only imagine another $100 or so for labor...........
Since it is under warranty, I may just take it to the dealer
