Rasing garage ceiling help..
Old Nov 18, 2009 | 11:16 AM
fade94's Avatar
fade94
Default Rasing garage ceiling help..
I'm will be pulling the trigger on a 4 post lift in the next couple of days. What I am looking for are folks that have raised the ceiling in the garage to gain lifting room.
PICS WOULD BE AWESOME!. I currently have a truss system on 24" centers running left to right. I want to at a minimum, raise a section in the highest point of the truss to allow close to full lift height.
Anyone?
Old Nov 18, 2009 | 11:35 AM
Capt Steve's Avatar
Capt Steve
In most garages, the ceiling sheetrock is nailed directly to the cross member of the roof truss that is attached to the roof rafter.
The rafters are meant to move the downward force from the roof to the outside walls. This cross member is used to stop the downward force of the roof from separating the roof rafters and collapsing.
In order to get additional height, you would have to remove the cross member. Without reinforcing the rafters somehow, the roof could cave in. This is especially important if you live in a area that gets snow or has high winds.
I would not suggest you just remove the cross members.
In order to change this, you would need to consult with a structural engineer who could design a new rafter system. You more than likely would have to remove the entire roof and rebuild it to the new specifications.
Old Nov 18, 2009 | 11:40 AM
acf5678's Avatar
acf5678
Anyone?
What lift did you select, I have been researching for a while but can't make a decision. I have looked at Bendpak, backyard buddy, and AClifts.
Old Nov 18, 2009 | 11:47 AM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
I agree, the trusses are not to be messed with. Only way is to remove roof, raise walls and then set trusses at the new elevation. Cutting a truss can bring the whole thing down.
LJ
Old Nov 18, 2009 | 11:51 AM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
I looked in to doing the exact same thing with a very similar truss system and 3 contractors that I had come to my house would not touch it....to much of a risk of a structural failure and much to costly to reinforce the roof....the whole roof would have had to have been removed and rebuilt....
Old Nov 18, 2009 | 11:53 AM
ohfiver's Avatar
ohfiver
Default ceiling not to low
I have a 4-post lift in my garage (12 ft. ceiling) and my neighbor has one in his garage his ceiling are standard height, here is what he does; just raise your car to the highest position (without) going through the ceiling and use a rolling chair to sit on and work on your car.
Old Nov 18, 2009 | 12:32 PM
Walkthedog's Avatar
Walkthedog
I am a general contractor. I have raised kitchen ceilings before that were trussed. I would not do what you are proposing until you talked with an engineer. Truss systems and stick built systems are engineered to carry a specific load. This load is calculated. Angles of joints, size of members, size of nails and where they are located all factor in. On occasion I have seen what is called a "drag truss" used, then piece of cake. However, if wrong you will not be eating cake! This is not do it yourself stuff, as seen on HGTV!
Old Nov 18, 2009 | 12:53 PM
acf5678's Avatar
acf5678
What brand of lift did you purchase?
Old Nov 18, 2009 | 02:09 PM
fade94's Avatar
fade94
Getting this lift. Paid for it just now. They will be delivering it and installing next Tuesday. I live just north of Dallas and this company is in Ft. Worth, so that helps.
Old Nov 18, 2009 | 02:16 PM
vettnut69's Avatar
vettnut69
Probably a way to do it right but would definitely talk with some one with structural knowledge first...
Old Nov 18, 2009 | 02:30 PM
vette4jr's Avatar
vette4jr
St. Jude Donor '09-'10-'11
Just like Fade94 suggested, the Pro Park 8S is the one to go for. I got mine through gregsmithequipment.com
Super happy with it. I paid to have it installed by a bonded/ licensed installer that gregsmithequipment.com referred.
They ship to the installer, who then trailered it to my house and installed it.
I figure if something were to go wrong, they're on the hook, not me and my 3 buddies.
FWIW, When I told the installer what I paid ( I think it was $1945), they were shocked...they said the lift was a steal and had features more expensive ones do not, and they liked how the lock ladder is adjustable, and you are not relying on welded in place pegs.
Also, if interested, you need a total of 7 of the drip trays to cover the entire midesection of the lift... I think it comes with 3, but gregsmith threw in an extra 3 (found out I was one short, but you can get by with the jack tray as the 7th if desired).
I find it is easier to work on the car with it lower on the lift and me on the creeper despite it having a 6' height.
Old Nov 18, 2009 | 02:55 PM
waldow's Avatar
waldow
St. Jude Donor '09
I am a GC also. In most (probably all) states, it is illegal to modify trusses without having an engineering letter from the TRUSS MANUFACTURER, not just from a structural eng. If it is an older home or if the truss manu. is no longer around, you may avoid the letter.
In the OP's case, raising the bottom chord ( as he describes the situation) will be a costly procedure at best. If you get a contractor that tells you differently, or "we don'ts need no stinkin letter"---- run!
Old Nov 18, 2009 | 03:03 PM
C6CPA's Avatar
C6CPA
Seems like an aweful lot of work and expense just so you can have a lift in your garage. Raising the actual roof???
Old Nov 18, 2009 | 03:13 PM
PCMusicGuy's Avatar
PCMusicGuy
Can you lower the floor instead?
Old Nov 18, 2009 | 03:24 PM
Top_Fuel's Avatar
Top_Fuel
Might want to check out this thread...
Raise Garage Ceiling
Old Nov 18, 2009 | 03:31 PM
acf5678's Avatar
acf5678
Appreciate the info!
Old Nov 18, 2009 | 03:47 PM
QUAKEJAKE's Avatar
QUAKEJAKE
LJ
No shortcuts!
To Rasing garage ceiling help..
Old Nov 21, 2009 | 10:24 PM
Red99Hardtop's Avatar
Red99Hardtop
You can cut the Trusses IF and ONLY you get an engineer to look at the job. You reinforce all the webbing of the affected trusses with girders. A new header has to be placed at the top to carry the roof load down on to the bearing walls. I did it in my garage, I raised the "box" 2 feet above the old ceiling height. Just got the lift delivered on Friday, putting that up after Thanksgiving.
Old Nov 21, 2009 | 11:51 PM
fade94's Avatar
fade94
Got pics????
Old Nov 23, 2009 | 11:26 PM
ccs1's Avatar
ccs1
I agree 100%
do not be intimidated by an engineer. You should be able to find someone who will come to your house and look at what you have a for a small fee engineer a fix. Probably add framing and bracing before you cut out for clearance.
