Constant Buzzing behind Dash (Cluster)
Old Nov 23, 2009 | 10:27 PM
knkali's Avatar
knkali
my wife calls this place the "oracle".
Old Nov 24, 2009 | 07:36 AM
beav626's Avatar
beav626
well I got in the car this morning and no buzzing.... so far so good
Old Nov 24, 2009 | 06:58 PM
kd6awa's Avatar
kd6awa
Cruising
I had the same problem with the temperature sensor fan last winter when the cold weather finally arrived (and the car was only a few months old). I think the sensor being mounted to the dashboard amplified the buzzing sound so I simply disconnected it from the dashboard and left the sensor hanging by its wires. Problem fixed (to my satisfaction, at least).
Old Nov 24, 2009 | 08:06 PM
beav626's Avatar
beav626
Have you had any issues with inside temperatures? Like not reading the temps accurately?
Old Nov 25, 2009 | 06:35 PM
kd6awa's Avatar
kd6awa
Cruising
I haven't noticed any issues. I figure the sensor's now sampling the air that's directly underneath the dash (since the unit is now simply hanging from the wire) rather than from in front of the dash. And my usual setting is floor vents only but it doesn't seem like the sensor is seeing just the heated air from the vents. I leave the inside temperature set at 74 and even with an outside temp of the high 40s or low 50s, it's comfortable.
Old Nov 26, 2009 | 05:36 PM
beav626's Avatar
beav626
Old Dec 2, 2009 | 09:40 AM
beav626's Avatar
beav626
Every once in a while that wire keeps rubbing the fan and it begins to buzz again...
Old Dec 2, 2009 | 10:00 AM
Nate's first vette's Avatar
Nate's first vette
I have that buzz too. it's at chevy right now. I'll post later if they fix it.
Old Dec 3, 2009 | 03:48 AM
Mel 2001's Avatar
Mel 2001
This is unbelievable!
I was going crazy wondering where that buzzing sound was coming from. It sounded Like it was coming from the engine compartment. But what could be making that sound from there?
Thanks for the OP. I hope the dealership has good ears.
I plan on telling them about the Buzz, the cracked starter button and the noisy differential, when I bring it in for my oil change.
Old Dec 3, 2009 | 09:25 AM
beav626's Avatar
beav626
last night mine was intermittent and annoying... My girl was asking why is the radio up so loud...
Old Dec 6, 2009 | 06:47 PM
beav626's Avatar
beav626
did they fix it?
Old Dec 6, 2009 | 08:31 PM
User 2623's Avatar
User 2623
Another considerations regarding Buzzing or Vibration noise which seems to be coming from inside the dash. This is however dependent upon speed, wind velocity and sometimes direction.
Check your windshield cowel - the black plastic strip below your windshield wipers and covering the lowest part of your windshield.
Basically tape it down alternating each side take it on the highway see if the buzzing or vibration stops. If so get it replaced at the dealer- warranty service for those who still got it.
Nonetheless it's responsibile for a number of complaints about dash vibration or buzzing. Check it out might work for you.
Old Dec 6, 2009 | 09:32 PM
  #33
jordyt123's Avatar
jordyt123
Had the same noise and the cowl vibrating at speed was the culprit.
First time the dealer used silicone to adhere the cowl piece to the window. Noise stopped but the cowl piece started to tear at the seams. Dealer replaced the whole cowl piece.
Old Dec 7, 2009 | 12:39 AM
  #34
Buffalo3's Avatar
Buffalo3
Raider, thanks for the info. I've got the same buzzing and have been searching in vain for its location.
Old Dec 7, 2009 | 12:45 AM
  #35
gbgary's Avatar
gbgary
i have this issue. taped it down to confirm my guess and all was quiet. took the tape off...noise. i hate to take it to the dealership but i guess i'll have to.
Old Dec 7, 2009 | 01:45 AM
  #36
Rossi6998's Avatar
Rossi6998
I love this forum and now know what the buzzing problem is. Now, I have to determine if the buzzing is more annoying then some mechanic ripping my dash apart and possibly creating another problem....
Old Dec 7, 2009 | 09:25 AM
  #37
beav626's Avatar
beav626
mine gets more annoying everytime I drive the car...
To Constant Buzzing behind Dash (Cluster)
Old Jan 19, 2010 | 02:14 AM
  #38
GotGrunt's Avatar
GotGrunt
I have the same buzzing sound... you can only hear it with the engine and accessories off while the ignition is in the run mode.
Old Jan 19, 2010 | 07:40 AM
  #39
beav626's Avatar
beav626
I have pulled that little fan out (The one next to the ignition button) and found that to be the culprit. I will take it to the dealer for replacement as the part is like $60-$70
Old Jan 19, 2010 | 08:06 AM
  #40
GotGrunt's Avatar
GotGrunt
Yeah, that's definitely the culprit. It amazes me all the cheap little components they put in such an amazing machine.
