C6 wheel question
Old Nov 29, 2009 | 04:55 PM
marliner's Avatar
marliner
Default C6 wheel question
Will C5 Corvette wheels 18 and 19 after market fit on a C6 coupe, Thanks.
Old Nov 29, 2009 | 05:15 PM
Zymurgy's Avatar
Zymurgy
Moderator
Really need more information. The bolt pattern is the same. C5 and C6 stock wheels have different offsets. Since these are after market wheels, you can safely assume the bolt pattern matches stock, but you have no idea about the width or offset. To know if they will "fit", we really need to know the wheel widths and offsets.
Old Nov 29, 2009 | 05:28 PM
marliner's Avatar
marliner
The wheels will be c5 offset 18x9.5 57mm front and 19x11 64mm back. Thanks
Old Nov 29, 2009 | 06:03 PM
Zymurgy's Avatar
Zymurgy
Moderator
OEM offsets:
C5 - 58 front/65 rear
C6 - 56 front/79 rear
OEM Widths:
C5 - 8.5/9.5
C6 - 8.5/10.0
So, with C5 offsets and 9.5 front and 11.0 rear widths, the fronts will extend about .4 inch further both inside and .6 inch outside. The rears will extend about 1.1 inches further outside and the inner clearance will only differ by 1mm.
I'd be concerned that you might rub the rear fender when the suspension compresses.
Old Nov 29, 2009 | 06:33 PM
marliner's Avatar
marliner
Thanks for the info, my c5 is Z06 my c6 is a z51 coupe auto, love both cars trying to sell the wife on interchangibility of wheels and tires, guess Ill have to order extra set of back wheels for the c6 lots of deals on wheels out there, looking at Bridgestone R-11s. Thanks
To C6 wheel question
