tire question
Old Nov 29, 2009 | 06:38 PM
NARIMAN's Avatar
NARIMAN
Default tire question
can i fit 325 tire on 11 inch wide wheels, it is 20 inch wheel?
Old Nov 29, 2009 | 06:46 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
give the complete tire size in order to get the question answered with proper accuracy..
ie: 325/35R20.... etc. the sidewall profile plays a major role.
Old Nov 29, 2009 | 07:31 PM
NARIMAN's Avatar
NARIMAN
so i understand the bigger side wall the bette for wider tire
i dont even know what tire brand makes 325/35/ 20
is there nitto invo in that size
Old Nov 29, 2009 | 10:37 PM
NARIMAN's Avatar
NARIMAN
also is there big differents between 315 wide to 345? is it worth going wide body because of that
Old Nov 29, 2009 | 11:10 PM
wolfdogs's Avatar
wolfdogs
no...... the "profile"......which inlcudes the most important Aspect Ratio:
http://www.tirerack.com/tires/tirete....jsp?techid=46
The Aspect ratio plays a major role in rim width..
a 325/35R20 tire size is not listed in the current edition of the Tire and Rim Handbook, which is the bible of the American Tire Manufacture's..... if that size is built, the manufactures web site should have the design rim width listed for it. You can go +- .05" on the rim width and stay in compliance.
Old Nov 30, 2009 | 12:28 AM
Zymurgy's Avatar
Zymurgy
Moderator
Wolfdogs, don't you mean +- 0.5", not .05"?
Old Dec 3, 2009 | 08:08 PM
wolfdogs's Avatar
wolfdogs
yes, thank you, typo.
Old Dec 4, 2009 | 12:20 AM
Wayne O's Avatar
Wayne O
CF Senior Member
You can easily run stock size Z06 supercar runflats...325 rear tires on 11" rims (with proper offsets) with your stock body C6. Whether your need to use 345's justifies the expense of using Z06 body panels or tubbing your rear wheel wells only you can decide.
To tire question
