Help finding Squeaky Pulley
Old Jan 11, 2010 | 05:04 PM
myquickZ06's Avatar
myquickZ06
I have an '03 with 9k miles and it just started to squeel when the engine is reved up. It squeels alittle while driving, but under moderate exceleration it squeels louder. What do you think guys?
Old Jan 11, 2010 | 05:35 PM
Sunset 05's Avatar
Sunset 05
To me, that sounds more like what I would expect from a bad/wet belt or a weak tensioner.
Old Jan 11, 2010 | 05:39 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
[QUOTE=Sunset 05;1572719384] The sound it made didn't sound like a squeal like a wet or loose belt. It was more like a chirp. It wasn't a steady noise, it was rythmic; you could tap your foot to it.QUOTE]
Thats exactly the way I would describe the way mine sounds!
Old Jan 11, 2010 | 05:43 PM
myquickZ06's Avatar
myquickZ06
Thank you, i'll check that out.
Old Jan 12, 2010 | 12:56 AM
HANNY's Avatar
HANNY
if you got a crayon laying around color up each belt one at a time while the engine is running (dont loose any digits tho) if the sound go's away then theres your problem belt. If it doesnt,,,,then a pulley is in order
Old Jan 12, 2010 | 06:13 PM
Sunset 05's Avatar
Sunset 05
Boy I got lucky!
Car is back, engine is smooth as glass, and all was covered by the warranty.
I'll make a final report in a few days, after I've had a chance to look it over really closely, but so far all is good.
Kudos to Jim *** @ Mac Haik Chevrolet.
Old Jan 12, 2010 | 10:11 PM
CH-Z51's Avatar
CH-Z51
Glad to hear all is well.
I'm anxiously awaiting you report as I'm still very concerned .
I'm considering replaceing mine with a quility aftermarket harmonic balancer. I'm just not sure I trust the integerity of the stock one.
Old Jan 13, 2010 | 06:30 AM
Sunset 05's Avatar
Sunset 05
CH - here's a youtube vid. of another member's car. Mine sounded the same, I just refused to believe (at first) that the balancer had or was preparing to fail.
I got lucky enough that when it went it was covered under warranty, and failed in an undeniable manner. I didn't have any arguement from the Service Writer or Tech about a failed balancer.
hood shut:
http://www.youtube.com/watch?v=4HmMAyPdyDs
hood open:
http://www.youtube.com/watch?v=vRboo9a0RnY&
in the hood open video you can see the runout of the balancer. Mine had less than that, but the squeak was very smilar. Mine was more rythmic...like I said before, you could tap your foot to it, but otherwise the same.
When mine failed the outer ring walked backwards into the engine. It started making a hell of a grinding sound in my driveway, but I shut the engine off ASAP. Dealer said there was no other damage, so I'm grateful for that. I was fortunate it didn't snap a belt or anything else.
Good luck with yours, and hopefully the vid's are informative.
Old Jan 13, 2010 | 09:31 AM
calemasters's Avatar
calemasters
hood shut:
hood open:
Based on the "hood open" video, the crank pulley lateral run out seemed normal. I have never seen an LS2 crank pulley that did not have some amount of run out. The tensioner motion also seemed normal.
Old Jan 13, 2010 | 12:03 PM
CH-Z51's Avatar
CH-Z51
Sunset 05 - The videos are interesting. In the first I would say mine has a more rythmic, consistant chirp more like what you previously described. It looked to me in the hood open video that the crank pully had more wobble or runout than what I'm seeing with mine.
Thanks for posting the videos. I to have a hard time wraping my head around the idea that I have a bad balancer but I just don't think its something I should ignore.
Old Jan 13, 2010 | 12:50 PM
Sunset 05's Avatar
Sunset 05
Something else you might try to help - pull the belt off and spin the pulleys by hand. All of mine were quiet and well lubricated. The alternator was a tad louder, but nothing serious. Might help you if you find out the alternator or waterpump is the culprit.
[edited to add] pulling the belt off is pretty easy. Just a 14 or 15mm socket (don't remember which one off the top of my head) to hold the tensioner back and then slip it off the water pump pulley [/edit]
Old Jan 13, 2010 | 06:54 PM
CH-Z51's Avatar
CH-Z51
I think thats a great idea! As soon as I have some time (retired) I'm going to get serious about diagnosing, but I have a bad feeling.
Old Jan 13, 2010 | 09:40 PM
  #33
SweetBlueZ51's Avatar
SweetBlueZ51
…here's a youtube vid. of another member's car.
hood shut:
hood open:
Those are my videos and it was a nightmare to finally get the damn thing fixed.
I KNEW it was the harmonic balancer/crank pulley all along but it had to get ridiculously worse over time for them to finally do anything about it. I went to several different GM service shops. Even drove HUNDREDS of MILES back to where I bought the car (Kerbeck in Atlantic City, NJ) where they flat out refused to fix it (amongst other things! Things that have now been fixed by a great service shop under warranty, go figure!).
I finally found a highly recommended service shop in my area (on here, thank you CF!), but even they wouldn't replace the HB initially. They replaced the main serpentine belt, but that didn't do the trick. Once they finally agreed to replace the HB after hearing now bad the car sounded, the car now runs as it should; perfectly smooth, no more chirping idling noises, the balancer runs almost dead true, etc.; it's like a whole new car. I wish you guys could have heard what it sounded under acceleration... it was a bird chirping fest under the hood but the idling in the garage under the car gets the undeniable point across that there was a problem, and it's name was "Harmonic Balancer".
Old Jan 14, 2010 | 01:47 PM
  #34
CH-Z51's Avatar
CH-Z51
SweetBlue - I thnk I'm in about the same place you were in the early stages, I appreiciate your input. I am just now considering ordering a aftermarket, solid steel HB W/the pinning kit and just doing the install myself just to avoid the frustraction of what you went through at the GM dealers. I will of course pay for this myself but I will at least know that the parts used are the best quility and the installation will be correct, "the first time".
Also considering a 25% underdrive HB. Just wondering what advise someone with a 25% under HB would give me about using one of these instead of a stock size? My LS2 is pretty much stock except for a tune and exhaust and I don't track my car.
Old Jan 14, 2010 | 02:39 PM
  #35
zero5see6's Avatar
zero5see6
This is exactly what I’m thinking about doing as my HB has a slight wobble. I’m a couple thousand units out of the affected VIN range, but I don’t want to take any chances. I have 25,000 mi on the car right now.
Old Jan 14, 2010 | 02:48 PM
  #36
L82Brake's Avatar
L82Brake
My 2006 Impalla SS sounded exactly like that. I thought it was the waterpump and waisted $45. Do you have a stethoscope? Thats how I found out and replaced the pulley was making the racket.
http://www.harborfreight.com/cpi/cta...emnumber=41966
Old Jan 14, 2010 | 05:45 PM
  #37
Sunset 05's Avatar
Sunset 05
Don't think that because you're out of the VIN range this can't happen to you (or anyone else). I'm outside the VIN range as well; #16389. This is a different type of failure anyway. The VIN-range failure deals with the bolt coming loose and falling out. This is more what I would call a ring separation failure since the outer ring separates from the inner ring.
I kept thinking I would be safe since I was outside the VIN range.
SweetBlue - is your car a manual? Mine is and I wonder if that isn't part of the problem.
To Help finding Squeaky Pulley
Old Jan 14, 2010 | 06:57 PM
  #38
zero5see6's Avatar
zero5see6
Sunset 05 - Thank you! Now that you mentioned it, I realize this is a different type of failure. I'm going to expedite the aftermarket HB install.
Old Jan 14, 2010 | 08:01 PM
  #39
ProudAmerican's Avatar
ProudAmerican
Boy I got lucky!
Stuff happens to the best of all autos. Just gotta accept it. When GM steps up to the plate and treats you correct....then we gotta tip our hats to GM.......
Old Jan 20, 2010 | 04:09 PM
  #40
s2kvince's Avatar
s2kvince
I'm in Houston as well and I get a mild squeaking sound. It only occurs when it's humid outside and it's either inaudible or it goes away when the motor is revved. Mine is a 2007 model.
Any ideas?
