From: Surgeon General never said anything about smokin' tires! Pigeon Forge, Tn.
competitive driving mode???
For some reason my car won't go into comp driving mode. Wanted to see if anyone had a simple solution as to why. Change oil light just came on a few days ago, wonder if that has anything to do with it.
I would think you would have seen a 'service tire monitor' warning but are all your tire pressure sensors registered correctly and working properly? If you have one or more TPS's 'out' you can't engage comp mode. Just a thought. Good luck!
just out of curiosity Im changing to a 9.5 front tire over an 8.5 will this cause any issues?
If you mean a 9.5" rim from an 8.5" rim----- The rim width doesn't matter, it's the DIAMETER of the tire you put on the wheel. The tire diameter depends on the sidewall width and the aspect ratio. I.E;
A 275/35/18 tire on an 18" X 9.5" rim is close to the same overall diameter as a 245/40/18 on an 18" X 8.5" rim.
Wayne O, you are on the spot. After checking, my left rear is registering 0, but manually have 31 pounds so this is obviously the issue. Thanks for the help.
