C6 Wheele Help
Dec 22, 2009 | 08:12 PM
C6 Wheele Help
Hey,
Does anyone know what the stock offset is on the front rim of a c6?
I have 18's in the front and 19's in the back.
Thanks!!
Dec 22, 2009 | 08:17 PM
+56mm front, +79mm rears
Dec 22, 2009 | 09:16 PM
Coupe/Convertible
Tire -- Wheel
Front: 245/40R18 18x8.5 (offset= +56mm)
Rear: 285/35R19 19x10 (offset= +79mm)
Z06
Tire -- Wheel
Front: 275/35R18 18x9.5 (offset= +40mm)
Rear: 325/30R19 19x12 (offset= +59mm)
21 pounds for each front wheel (+/- 0.5 lbs)
25 pounds for each rear wheel (+/- 0.5 lbs)
C6 non Z06
Front 18 x 8.5, +56 mm offset
Rear 19 x 10, +79 mm offset
C6 Z06
front: 18 inch x 9.5 inch, +40 offset
rear: 19 inch x 12 inch, +59 offset
Dec 23, 2009 | 04:13 PM
I need to replace my front rim and found a new OEM Wheel with a 46mm offset... Is that a big difference?
Dec 23, 2009 | 04:21 PM
Dec 23, 2009 | 04:47 PM
Quote:
Originally Posted by
VinC6
10mm is about 0.3937 inches. This means the wheel/tire will stick out that distance more than the stock wheel/tire combo.
Dec 24, 2009 | 07:46 PM
Would you buy an OEM rim with a 46mm offset or a replica with a 56mm offset?
Dec 24, 2009 | 11:19 PM
How can an "OEM" rim have a 46mm offset? That is not original equipment specification.
Dec 25, 2009 | 11:25 AM
Must not be OEM. the OEM would have the OEM offset. Probably a reproduction wheel of some sort. Anyway you don't want to mix the offset same as not mixing sizes, etc. Car wont be right.
Jan 4, 2010 | 02:40 AM
3rd Gear
Your front tire size aspect ratio (tire height from rim to ground or diameter) is too high, it should be a 35 series not 40. You probably should have gotten something like a 255 or 265-35-18 for the fronts. The rears you'll probably need a wider spacer and probably went with 295-30-18 series tires for the rears.
antigua family resorts free cricket wallpapers
