Programming options
Old Jan 11, 2010 | 08:21 PM
65GGvert's Avatar
65GGvert
Default Programming options
I just entered the C6 world after having multiple C2's, C3's and C5's. (Still have the 78 Silver Anniverary). I can program the personal options on the DIC when the engine is running, but cannot get into it from any other mode. Is there a way to enter the options program without starting the car? I've tried acc and multiple combinations, but no dice. It's an 08 convertible. Any help?
Old Jan 11, 2010 | 08:56 PM
BEZ06's Avatar
BEZ06
If you've got a manual transmission, the clutch has to be pushed in to start the engine.
So.....put it in neutral and without stepping on the clutch pedal, push the top of the ignition button as if to start the car. That will power up everything without cranking the engine.
If you've got an automatic, I dunno what to do! I think you need to push on the brake pedal to get it to crank, so you might be able to get everything to power up by pushing the top of the ignition button but without stepping on the brake pedal.
Good luck!!
Bob
Old Jan 11, 2010 | 09:14 PM
avizer's Avatar
avizer
On automatic you need to press the bottom of the start to enter into ACC mode
Old Jan 11, 2010 | 09:20 PM
johnodrake's Avatar
johnodrake
Moderator
To put the car into the engine off, ignition on mode, press the bottom of the start switch and hold for >5 sec.
Old Jan 11, 2010 | 09:44 PM
65GGvert's Avatar
65GGvert
Thanks, I'll try that. It's an automatic.
Old Jan 11, 2010 | 10:40 PM
65GGvert's Avatar
65GGvert
That did it! Thanks for the help.
To Programming options
