dead battery drain problem
Only '05's have to be put in reverse.
The computer searches for the presence of the fob only when it's asked to do so, like trying to open a door and trunk, or starting the car.
The fob being in or near the car does not keep the computer up and running and drawing excessive power.
At least that's the simplified explanation as I recall from Forum Guru Talon90.
My '06 A6 with the OEM battery still in, has sat for as long as 3 weeks and still started up. Granted this wasn't the dead of winter, but if the battery is only lasting a few days, something is definitely wrong.
I normally have mine on a battery tender if it's going to sit for more than a few days.
I took my car to the dealership and they supposedly "reflashed" the computer. Well, it has happened since the "reflash." To everyone: I put it in reverse and I do not leave lights on! I've bought three new batteries, and it has had a new alternator. It is a great disappointment and I will not buy another corvette. End of story and the end of GM.
I have a 2005 and had DBS 6 times. It took 3 batteries and a re-flash to fix the problem. Dealer never gave me any excuses. The re-flash worked for me.I will NOT put a battery tender on a $60K car. You shouldn't have to put bandaids on expensive cars. Only time I use a tender is when it is in storage, December through March.
My C5 has a Optima Red Top, and I put a battery float charger on it whenever I'm not going be using it. ! Good Luck.
In agreement with covering the basics that have been outlined here. In some cases the problem is corrected
I believe there are intermittent cases were the solution has not been identified.
Mine for one when you connect a DC current meter is series so you can the actually see current draw in MA as various cct's shut down.........works perfectly every time. I can leave that meter connected for two weeks, then start the car.
Oh & yes with key Fob in close proximity to the car all the cct's shut down correctly. So no to the key Fob must be away from the car....you can leave laying in the car.
Disconnect the meter re attach the battery terminal.....all is good, for a while. Then it sits for a few days & you go to start "Dead Battery"
I have covered the basics, on my third GM Delco battery. Cognizant of my shut down procedure! I know how to run & connect DC current meter in MA.
Yes I have a CTek Tender out of frustration.
I'm convinced there is an intermittent problem & I've somewhat exhausted my troubleshooting idea's.
I pick up on these threads hopping someone has identified this annoying problem.
Bill
My 07 draws 18ma. It will discharge a battery if it sits long enough. I use a tender if it sits longer than a couple days and I don't mind because it increases the life of my battery. The draw on the battery is the price we pay for a car loaded with fancy electronic options. If GM could reduce the draw I'm sure they would. Using a tender is no biggie if you run the cable to the grill and park in a garage with power. I would complain a lot more if I had to park on the street but then it probably wouldn't sit long with out being driven.
Remember a drive of only a couple miles is not enough to keep a battery fully charged even if you do it every day with the vettes draw.
Most people seem to like electronics. I like electronics so I don't mind using a tender. It only takes 20 sec or less to hook it up after I get out of the car.
If you buy a C6 you will have to get over the tender or trade it for a Viper or a Cobra kit car or something with few fancy electronics. Now some owners will state they never use a tender in any weather/driving habits and never have a problem but I think they are not the majority.
One of the advantages of using a tender is extended battery life. I have been using them for 20 years and buy few battery's. I expect the original battery in my 07 to last a 5 years.
[IMG]
[/IMG]
Id say your battery is toast and they need to give you a new one. Check it out and let us know what you find.
Bill
I have left my 08 for 3-4 weeks and it started right up showing 14.6 volts. During oil changes, I will hook up my Ctek battery charger to make sure the battery stays in a healthy state. Keeping the battery in a healthy state will prolong the life of the battery cells. Once these cells are damanged, the battery will not hold a charge.
If you have a digital volt ohm meter with a 10a range on it (most do) hook it between one of the cables and the battery post when you install the battery this spring and see if you have a draw greater than 25ma. Wait several min before reading the meter to allow the circuits to quiet down. If you do this yourself it will save you from taking it to the dealer for the usual scratches and other damage they happily provide no charge to you.
Now I will have to go thru the trickle charger nonsense because I want the car to start, the battery to last and don't want to deal with the inability to get in my own damned car.
HEY GM! WAKE THE HECK UP AND FIX THIS PROBLEM! THERE ARE WAAAY TOO MANY PEOPLE ON THIS FORUM WITH DEAD BATTERIES.
We don't know exactly how many of the 164,000 C6's are experiencing a discharged battery problem but hear a lot about it on the forum.
If your car has the problem I guess you will have to:
1. Use a tender, forget about it and enjoy the car.
2. Drive it every day and enjoy the car.
3. Figure it out, fix the problem yourself and enjoy the car.
3. Trade it off and tell everyone you know C6's suck
Right now I choose #1.
