HUD Install Complete
rl1360@yahoo.com
Phone: 309-335-3144
And search the C5 General forum and C5 Tech/Perf forum for more info.
Larry in Long Beach is a forum member who makes a HUD wiring harness. We exchanged messages; he can do the install. I don't recall his forum name... contact info on his ebay ad ("NEED IT INSTALLED.... IF IN SO-CAL I CAN INSTALL IT FOR YOU").
HUD install links:
HUD install, easy cut-the-duct method (pics)
HUD install, easy cut-the-duct method DIY instructions
Complete HUD install instructions, pics & wiring diagrams
Read the whole thread. See what people say about their installed HUD. Read this one, too: http://forums.corvetteforum.com/c6-c...staxi-com.html
I've read every thread on C6 HUD installs I can find. They all say the non-HUD windshield works just fine. Best estimate I recall (Talon90 post?) is that readouts on the non-HUD w/s look about 95% as good as the HUD w/s. Can't recall ANY negative posts.
Just got my HUD parts yesterday. I plan to install 'em as soon as the weather warms up.
I know I can install it myself I just dont want to void the warranty.
Maybe you could come up with an automotive standard wiring harness to go with your service. Some people have the misconception of aerospace standard being superior. It is true that if components/systems fails, planes will fall. It is simply because of that concept, redundancy is built into components/systems to have back ups, thus, material used needs only meet basic needs. Where in automotive, if one component failed, it will not run or in racing condition, will end up with DNF. ARP came to be because of that fact.
****Disclaimer **** That is what I've personally seen. I have gotten phone calls from folks that did it themselves and have really screwed some stuff up. ie buttons on right hand side stopped working and a few other things.
I would not use fold over connectors to tap into a wire! Wire is squeezed and abraded and that compromised the integrity of the wire. Granted, problem from the compromised wire sometimes would not be immediate but it will surface when you least expected. Soldering is the trouble free route but it is more time consuming.
Another area most people neglected is the HUD motor pivot mount weekness as reported by forum member gr86ss. That needs to be address properly if one want to avoid unneeded future problems prior to the installation.
Thought this might be as good a place as any to offer my $.02
I have sold literally 1,000's of these kits, all supplied and installed with the "fold over" spade lock connector. Out of all of those, there have been 2 reported problems due to those connectors, and truthfully, those were debatable whether it was the connector or the installer. I just sent replacements to take care of my customers.
On the issue of soldering, from electrical engineer point of view (have had this same conversation with quite a few of them), I understand the school of thought, and have soldered many items working in my home or garage. Now, in the land of General Motors, soldering is a carnal sin. There are numerous service bulletins stating to never solder on a GM vehicle. In talking to some of our field engineers, and guys in Michigan, they all cringed when I asked the question "why not?". The most common reasons were not wanting to cause a second problom while trying to repair the first by;
1) Burning through the wire attempting to repair and breaking connection.
2) Piling up too much solder in one spot, causing too much resistance in the wire.
3) Heat transfer through the wire and causing internal damage to a control module (pick one, doesn't matter which one).
Even the factory trained GM World Class technicians, who are the best of the best, are told not to solder, but either cut and splice, or replace said wire.
Hope this helps shed some light on it.
Kevin
www.PartsTaxi.com
As for warranty, nothing can VOID your warranty (except for rebuilding a salvaged car, or not changing your oil for 10 years, etc). Being this was not factory installed, it is not covered by the warranty. If it is installed improperly, say maybe cross some wires, and ends up frying the BCM, the BCM repair will not be covered under the warranty because it was an add on product that caused the failure. But, you install the HUD and your engine spits the crankshaft through the oil pan (highly unlikely, just an example), they are in no way related, and the engine repair would be covered.
