head light problem
Old Jan 23, 2010 | 10:58 PM
stillcrazy's Avatar
stillcrazy
Default head light problem
I live here in SoCal,we have had alot of rain here lately. When I got home yesterday I found that the drivers side headlamp bucket was covered with moisture on the inside. I called my dealer and complained. The dealer told me that before they could replace it,the headlight would have to set indirect sun light for two hrs. I was not happy so I took it to the dealer right away. When I got there and asked to see the service manager I was told they wanted to see it and they agreed to replace it on the spot, your opinions.
Old Jan 23, 2010 | 11:01 PM
cclive's Avatar
cclive
Its just condensation and is normal in a condition like that. It will dry out and be fine.
Old Jan 23, 2010 | 11:51 PM
NVR LAT's Avatar
NVR LAT
You might want to open the access panel in the wheel well and make sure the rubber caps are in place sealing the opening to the bulbs. I guess if the dealer is willing to replace it, then I might not worry about it, unless your headlight lenses are showing some signs of wear...then you would have one "weathered" lense and one "new" (I'm assuming they are only replacing one).
Old Jan 24, 2010 | 12:08 AM
stillcrazy's Avatar
stillcrazy
no my car is an 08 ZO6, so it's like new, they are replacing the driver side.
Old Jan 24, 2010 | 09:02 AM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
You are aware that normal condensation in the headlight is normal....right.
I mean it does state it in the Owner's Manual.
But w/o pics, maybe you have an extreme amount of water, since the dealer agreed to replace it.
Old Jan 24, 2010 | 10:05 AM
calemasters's Avatar
calemasters
As per the DTB:
2008 Chevrolet Corvette | Corvette (VIN Y) Service Manual | Document ID: 2271933
#01-08-42-001G: Exterior Lamp Condensation and Replacement Guidelines - (May 4, 2009)
Subject:Exterior Lamp Condensation and Replacement Guidelines
Models:1993-2010 GM Passenger Cars and Trucks (including Saturn)
2003-2010 HUMMER H2
2006-2010 HUMMER H3
2005-2009 Saab 9-7X
This bulletin is being revised to add the 2010 model year. Please discard Corporate Bulletin Number 01-08-42-001F (Section 08 -- Body & Accessories).
The following information is being provided to better define the causes of condensation in exterior lamps and includes guidelines for determining the difference between a lamp with a normal atmospheric condition (condensation) and a lamp with a water leak.
Some exterior lamps, such as cornering, turn signal, backup, headlamps or tail lamps may exhibit very small droplets of water, a fine mist or white fog (condensation) on the inside of the lamp lens. This may be more noticeable on lamps with "multi-lens" designs and may be normal during certain weather conditions.
Condensation occurs when the air inside the lamp assembly, through atmospheric changes, reaches the "dew point". When this takes place, the moisture in the air within the lamp assembly condenses, creating a fine mist or white fog on the inside surface of the lamp lens.
Most exterior lamps on General Motors vehicles use a vented design and feature a replaceable bulb assembly. They are designed to remove any accumulated moisture vapor by expelling it through a vent system. The vent system operates at all times, however, it is most effective when the lamps are ON or when the vehicle is in motion. Depending on the size, shape and location of the lamp on the vehicle, and the atmospheric conditions occurring, the amount of time required to clear the lamp may vary from 2 to 6 hours.
Completely sealed headlamp assemblies (sealed beams) are still used on a limited number of models being manufactured today. These lamps require the replacement of the complete lamp assembly if a bulb filament burns out.
A Fine Mist or White Fog on the Inside Surface of the Lamp Lens Occurring After a Period of High Humidity
• May be located primarily in the lens corners (near the vents) and SHOULD NOT cover more than half the lens surface.
• The condition should clear of moisture when the vehicle is parked in a dry environment, or when the vehicle is driven with the lights ON.
• A comparison of the equivalent lamp on the opposing side of the vehicle indicates a SIMILAR performance.
If the above conditions are noted, the customer should be advised that replacement of a lamp assembly may not correct this condition.
Numerous & Various Size Drops of Water Collecting on the Inside Surface of the Lamp Lens After the Vehicle Has Been Exposed to Rain or a Car Washing Environment
• A condition that covers more than half the surface of the lamp lens.
• An accumulation of water in the bottom of the lamp assembly.
• A condition that WON'T clear when the vehicle is parked in a dry environment, or when the vehicle is driven with the lights ON.
• A comparison of the equivalent lamp on the opposing side of the vehicle indicates a different performance.
Any of the above conditions would indicate the need to service the lens or lamp assembly.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2010 General Motors. All rights reserved.
Old Jan 24, 2010 | 10:57 AM
stillcrazy's Avatar
stillcrazy
It's been two days and the headlight is still covered completely. So this exceeds what is considered normal. The right side fogged over but it cleared
Old Jan 24, 2010 | 11:06 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Way to go --you got the service you deserve.
Old Jan 24, 2010 | 11:09 AM
cclive's Avatar
cclive
Have you driven the car in dry weather yet?
stillcrazy's Avatar
stillcrazy
Originally Posted by calemasters
As per the DTB:
[LEFT]Models:1993-2010 GM Passenger Cars and Trucks (including Saturn)
2003-2010 HUMMER H2
2006-2010 HUMMER H3
2005-2009 Saab 9-7X
Thanks for the bulletin,and after two days my headlight cover is still covered completely so it falls under replacement guidelines.
To head light problem
