Safe plugging runflats?
Old Jan 29, 2010 | 06:20 PM
Zymurgy's Avatar
Zymurgy
Moderator
Originally Posted by hawkgfr
doo doo.....
Its a tire..if it has a nail pull it plug it plug it pump it move on. You don't even have to take the tire off the car. Yes it is a performance tire but most Vette owners go 20 under the speed limit...
I would not recommend it on the edge or sidewall...But I have done that before and it went 20,000 miles with no problems. I stayed away from 150 mph runs though.
Yes, it is a tire. No tire should be repaired with just a plug. Per the NHTSA:
The proper repair of a punctured tire requires a plug for the hole and a patch for the area inside the tire that surrounds the puncture hole. Punctures through the tread can be repaired if they are not too large, but punctures to the sidewall should not be repaired. Tires must be removed from the rim to be properly inspected before being plugged and patched.
There are actually very good reasons for this. A tire that is simply plugged from the outside may fail catastrophically in the future. The tire may have structural damage that simply cannot be seen from the outside of the tire. Moisture can penetrate from the inside and cause the belts to fail. Proper inspection and use of both a plug and patch eliminate these possibilities. Just because you have had no problems in the past does not guarantee equal success in the future.
I cannot understand why anybody would be so cheap about something as important to your safety as tires are. Heck, as mentioned above, there are places that will do a proper repair for free.
Your advice is irresponsible and inexcusable.
Old Jan 29, 2010 | 08:37 PM
hawkgfr's Avatar
hawkgfr
crickets....It MIGHT fail without anything happeneing too it....
You could walk out in the yard and have 50 pounds of frozen PEE fall on you from the sky too....
Old Jan 29, 2010 | 09:13 PM
986_C6's Avatar
986_C6
Plug them yourself....5 bucks....ten minutes.
I agree...I have done 3-4 runflats and very successful for many miles. Just as long as they are nowhere near the sidewalls.
Old Jan 29, 2010 | 09:23 PM
goatts's Avatar
goatts
Originally Posted by JERGENSENLS3
I would not plug a high performance rated tire
I would let a Goodyear certified tire shop make the call. JMHO
I might not want to take it on the track but I've been plugging my tires for years and it will be fine for normal use. Modern plugs work quite well.
Old Jan 29, 2010 | 09:26 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
I have no problem using plugs on my truck tires....but I'm not comfortable using them on the Corvette tires.
Old Jan 29, 2010 | 09:28 PM
JERGENSEN LS3
doo doo.....
Ask member Wolfdogs, about using plugs. He is the tire expert on the forum.
Old Jan 29, 2010 | 09:43 PM
goatts's Avatar
goatts
And a meteor may hit your car on your way home from work. How far do you want to carry this? A tire manufacturer may tell you that driving on a tire with low pressure will cause structural damage. You going to replace your tire if you find it's been under-inflated? We have six cars and I've been plugging tires for years.
Old Jan 29, 2010 | 09:50 PM
goatts's Avatar
goatts
Yes, I prefer a patch on the vette tires only because of frequent trips to the dragstrip, autox etc.
Old Jan 29, 2010 | 10:13 PM
2006c6keller's Avatar
2006c6keller
Default ???
One question, were do you find air that has NO moisture in it? Every filling station seems to have moisture in its air and when I use MY OWN tire pump the outside (source or ambient) air has moisture in it. I'm .
Old Jan 29, 2010 | 10:34 PM
hawkgfr's Avatar
hawkgfr
shhhhhh............he will be out there blowing a hair dryer on his tires....
Old Jan 29, 2010 | 10:35 PM
hawkgfr's Avatar
hawkgfr
I know of at least two other things he is an expert on...
Old Jan 29, 2010 | 11:24 PM
jerseyz's Avatar
jerseyz
i'm in the car biz and when my runflat picked up a nail or spike i took it to my service guys and told them to plug it they said you can't plug these. i said i don't care plug it anyway never had another problem with the tire
Old Jan 29, 2010 | 11:42 PM
  #33
Dendk's Avatar
Dendk
hmmm plugging a tire with a car that can almost reach 200mph and is meant to be driven hard. No thanks, I will pass and do a patch/replace if needed.
Old Jan 30, 2010 | 12:39 AM
  #34
cclive's Avatar
cclive
Safety, schmafety...who cares about safety...
Old Jan 30, 2010 | 05:16 PM
  #35
Zymurgy's Avatar
Zymurgy
Moderator
Agreed. And I certainly can't do anything to prevent it. However, it is very simple to get the proper repair done to a tire.
And he will tell you that the NHTSA is working to get plug repairs outlawed.
And a meteor may hit your car on your way home from work. ... We have six cars and I've been plugging tires for years.
Silly anology. One you can do nothing about (a meteor). On the other hand, doing a proper repair versus an improper repair is easy to do.
As I said earlier, just because you have not had problems in the past does not mean you will not have a problem in the future. The NHTSA wants to make simple plug repairs illegal because failures have been traced to them. Again, it is easy (and perhaps even free - Discount Tire) to have a proper repair done.
Who ever said that you could get moisture free air? I didn't. What I said was that without a patch, moisture in the tire can enter the "wound" and cause additional problems. The patch solves this problem.
Obviously, some members here don't.
Old Jan 30, 2010 | 05:46 PM
  #36
bosco 08's Avatar
bosco 08
what did you think will happen with a plug at speed, that it will just fly out and you instantly lose pressure?
this is the best plug kit made the ones that you have ream out the hole then insert a plug only do even more damage to the cords. these plugs vulcanize themselves as you drive the vehicle. carry this kit and a Slime pump and your problems are solved. btw if you don't trust the repair then buy a new tire at least you're home.
http://www.dynaplug.com/
http://www.gadgetjq.com/slime_pump.htm
Old Jan 31, 2010 | 10:18 PM
  #37
hawkgfr's Avatar
hawkgfr
Here have some cheese with that whine....Plugging tires will never be banned lol...It is also highly unlikely water with get buy a pressurized sealed plug.
You can also limit the danger of getting clubbed on the head by falling PEE.... wear a TIN FOIL hat.
To Safe plugging runflats?
Old Jan 31, 2010 | 10:23 PM
  #38
cclive's Avatar
cclive
Actually, what can happen is that since the plug is a foreign body in the carcass of the tire, it can generate extra heat in that area and at high speed, the tire can build up enough heat to come apart. Probably a long shot, but you wouldn't catch me on the highway out here in the west in the summer with a plug stuffed into my tire.
Probably not a big deal if you live where no one goes more than 55...
Old Jan 31, 2010 | 10:46 PM
  #39
Iwasachief's Avatar
Iwasachief
5th Gear
I was stupid and bought the tire warranty from the dealer when I bought my new Vette. Took a trip and got hold of a sheet metal screw in the rear. Had a plug put in at a dealer and kept on rolling on my trip for 900 miles. Had the tire replaced for free a couple of days later. Worth the price of the warranty.
Old Jan 31, 2010 | 10:52 PM
  #40
jschindler's Avatar
jschindler
It's a runflat tire - what's the worst that happens? It runs flat again
BTW, I would NOT simply use a plug except to get me to where it can be taken off and patched from the inside. That I have had done many times and they are very reliable.
