Safe plugging runflats?
Old Jan 31, 2010 | 11:01 PM
  #41
cclive's Avatar
cclive
I never knew about the whole falling frozen pee thing...maybe I should not have gotten the convertible...
Old Feb 1, 2010 | 12:23 PM
  #42
hawkgfr's Avatar
hawkgfr
Don't worry...you only gotta worry if it falls on a day with a Y in it.
Old Feb 1, 2010 | 12:54 PM
  #43
bosco 08's Avatar
bosco 08
Actually, what can happen is that since the plug is a foreign body in the carcass of the tire, it can generate extra heat in that area and at high speed, the tire can build up enough heat to come apart.
but a foreign body "on" the inside of the tire won't? i.e. a patch
i find it hard to believe a simple plug could cause a tire to "come apart" or fail due to extra heat. only cord damage could do that and a patch won't fix that either.
btw do you have a link describing this extra heat build up that causes a tire to come apart.
Old Feb 1, 2010 | 01:37 PM
  #44
cclive's Avatar
cclive
There is nothing rubbing against a patch on the inside of the tire that would generate heat. Almost all heat in a tire is generated by friction, the flexing of the tire. This is why under-inflated tires are dangerous. When they have low pressure, they flex more. A plug stuck in from the outside is a foreign body in the carcass...the extra friction in that area can cause more heat in that area...get enough heat and say good bye. Heat causes cord damage...a la Firestone a few years ago. Same internal friction is demonstrated by taking a metal bar and bending it back and forth with your hands...it will get hot at the bending point from the internal friction. All tire companies say not to plug a tire from the outside....thats all tire companies...maybe they know something about tires.....
Old Feb 1, 2010 | 07:40 PM
  #45
goatts's Avatar
goatts
Actually, Al Gore says that due to global warming most of the falling frozen pee is no longer frozen.
Old Feb 1, 2010 | 07:43 PM
  #46
goatts's Avatar
goatts
The explanation for this is probably too complex for us the understand.
Old Feb 1, 2010 | 07:47 PM
  #47
goatts's Avatar
goatts
See, too complex, but if you filled the tire with frozen pee then you've got something.
Old Feb 1, 2010 | 07:50 PM
  #48
hawkgfr's Avatar
hawkgfr
Al Gore is the perfect reason why plugging isn't permanent....
Old Feb 2, 2010 | 10:16 AM
  #49
Torch Ace's Avatar
Torch Ace
Al Gore needs to be plugged - for good
Old Feb 16, 2010 | 10:25 PM
  #50
humvet's Avatar
humvet
Old Feb 16, 2010 | 10:30 PM
  #51
hawkgfr's Avatar
hawkgfr
Yes...I agree 10000%
