Adding Nav
Old Feb 5, 2010 | 08:46 PM
Ames's Avatar
Ames
Default Adding Nav
I've been reading threads and wanted to confirm what I've found on adding Nav to a non-nav C6.
It's plug and play with a Bose/XM C6. Just need a GPS antenna.
05-08 can all use any year Nav. For steering wheel control's you need an 07-08 Nav.
09-10 need a Nav from 09-10 because of BT. <-- Really not sure on this one.
Old Feb 6, 2010 | 12:48 PM
Ames's Avatar
Ames
No one?
Old Feb 6, 2010 | 01:56 PM
RicK T's Avatar
RicK T
Yes
Yes
and
Yes
Old Feb 6, 2010 | 04:09 PM
Kent1999's Avatar
Kent1999
Yes to all.
Additionally, you'll also need to add the microphone if you want the voice commands to work for the nav ("show gas stations", etc)
EDIT: If you are buying a used Nav radio, don't forget the trip to the dealer to 'marry' your used radio to your car's VIN (VIN Relearn proceedure with a Tech2 tool)
Old Feb 6, 2010 | 04:46 PM
Ames's Avatar
Ames
Originally Posted by RicK T
Yes
Yes
and
Yes
Thanks!
Originally Posted by Kent1999
Yes to all.
Thanks! Do you know the part number on the mic? Is that on all years? When I was searching around I didn't see mention of the mic; only the gps antenna.
To Adding Nav
