basic C6 corvette
Old Feb 27, 2010 | 12:33 AM
jjrctech's Avatar
jjrctech
Default basic C6 corvette
Hi what is the different between 315/30/19 or the 315/40/19 ?
and would this tire fit on a basic c6 with the ace zr1 wheels 19x11 rear
Old Feb 27, 2010 | 12:43 AM
haljensen's Avatar
haljensen
First thing you need to know is that you have to stay very close to original diameter of the stock tires for everything to function correctly.
Diameters can be found here;
http://www.1010tires.com/TireSizeCalculator.asp
Old Feb 27, 2010 | 12:46 AM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
The side wall height of the 315/30/19 is 30% of the width of the tire, or 94.5mm. for the /40/ it's 40% of the width or 126mm. So the 315/40/19 will be a taller tire with the same width.
When you change tires sizes it can effect your active handling systems, so you need to keep the relationship between the front and rear tires the same or as close to stock as possible, or your active handling will act up.
As far as if they will fit a 19x11, yes, but they will stick out past the fender with stock offsets.
Old Feb 27, 2010 | 12:52 AM
jjrctech's Avatar
jjrctech
Yea I have those new wheel
19 x 11 rear with 285/35/r19 and front 275/35/r18 tires , but am get alot of tire spin with them so I was thing to go with 315mm tires in the rear.
What do you guys thing would work best, and not get tire spin.
Thanks for the help
To basic C6 corvette
