I just had one !
The rubber cover on the inboard headlight had come loose, and the sneaky critter found it.
There is just enough room for the fishtank tube catheter...
I just had one !
I had the same issue on the left side, including finding the dust boot loose. Used this tip and it worked great, the only problem I had was the tubing I used, from a brake bleeding kit ( was not used to bleed brakes, so was still clean). The tubing was very soft and did not want to go where I wanted it to go, but it took a while and I got the little critter.
Thanks for the great little tip.
I've got a moth in my front left light, too. It's been there for years. I'm going go try this when I detail it this winter. Amazing how common some problems are.
