Help battery dead can't get in car.
Old 04-11-2010, 11:53 AM
garrace
garrace's Avatar
Default Help battery dead can't get in car.
The battery in my 05 convt is totally dead and I can't unlock the car to open the hood and the owners manual is inside the car. Is there a way to manually unlock it or release the hood from outside?
Old 04-11-2010, 12:08 PM
LarryMJones
LarryMJones's Avatar
St. Jude Donor '13-'14-'15-'16-'17
Do you have the key that fits in the key slot above the license plate?
If you do you can open the trunk and then pull the cable to open front door.
If you don't have a key your dealer can probably mahe you one from the VIN .
LJ
Old 04-11-2010, 12:11 PM
VETTE IV
VETTE IV's Avatar
See the C6 2005 User Manual page 2-14/15 in the C6 FAQ sticky at the top of the page.
RICH 28
RICH 28's Avatar
Use the key. It goes in above the rear license plate. Once inside the trunk, pull the door release cord that is located above the driver side rear wheel well.
You do have a key, right?
Old 04-11-2010, 12:20 PM
CQRT
Support Corvetteforum!
CQRT's Avatar
Link to on-line owners manual in the FAQ section:
http://forums.corvetteforum.com/c6-c...tions-new.html
Once opened, I believe there's a pull that will open the doors - - I've got a coupe, so once you're in, you can pop the handles on the floor next to the seat.
I'm sure others can advise or you'll see the way in the trunk.
Old 04-11-2010, 12:27 PM
Vette_DD
Vette_DD's Avatar
Received 1,277 Likes on 935 Posts
Once you solve this problem, find a place outside the vehicle to store the owner's manual.
Old 04-11-2010, 12:35 PM
garrace
garrace's Avatar
Default Thanks
Thanks again. Once more you guys have been a lifesaver.
Garrace
To Help battery dead can't get in car.
Quick Reply: Help battery dead can't get in car.
