Firestone FireHawk run flats
Old Apr 18, 2010 | 05:25 PM
framebender's Avatar
framebender
I just replaced the orignal goodyears with the firestone runflats because of what I've read about the noise factor. The goodyears only had 7000 miles on them but they were very noisey. the firestones are much quieter, and I am very happy with them. As far as I'm concerned the handling of the car is pretty much the same. The stones might be a little more grippy, but they are new and softer.
Old Apr 18, 2010 | 05:30 PM
Scooty Puff Sr.'s Avatar
Scooty Puff Sr.
I can tell you they sure do drive better in the rain that the OEMs with 3/32" of tread! We have about 1,000 miles on our new Wide Ovals and love em'.
Old Apr 18, 2010 | 08:04 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by BostonJoel
Was the $710. for 2 or for 4 tires?? Seems pretty cheap for all 4.
Thx.
Old Apr 18, 2010 | 08:46 PM
Onyasix's Avatar
Onyasix
Originally Posted by POPA-VT
Have recently been pricing FS for my vette and best I could get was $916 did you get them local or online
It helps to know someone that works at the Firestone plant.
Thx.
All Four.
Old Apr 18, 2010 | 09:28 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by jpuli28
Any confirmation on rumors that the FS Wide Ovals are not "true" run flats? How about width discrepancy, are the Ovals truly narrower than the GY?
The official Firestone policy is that their C6 runflats should not be repaired if driven at all below 16 (?) psi.
A runflat that you can't run flat.
But you can work around that by buying their road hazard warranty at a pretty cheap price, and putting a small compressor that runs off your cig lighter, in the trunk cubby. If you get a slow leak, air it up and drive until it gets down to 18 psi, refill. Repeat as necessary til you get to the tire repair place. If it won't hold air at all, good chance it can't be repaired anyway so just drive it (50 miles/55 mph max, please).
The autocrossers I talk to say that the Michelin PS2 ZP is the best AX runflat, followed by the stock Supercars. They say the Firestones are better than the base runflats but not as good as the Supercars. But for 90% of Corvette drivers, the 'stones are a good compromise.
Old Apr 18, 2010 | 10:05 PM
Zymurgy's Avatar
Zymurgy
Moderator
... How about width discrepancy, are the Ovals truly narrower than the GY?
No. In fact, the Firestone Firehawk Wide Ovals are WIDER than the Goodyear. Per data on Tirerack:
.............---------- Front ------------ ..... ---------- Rear -------------
............ Section Width ... Tread Width ..... Section Width ... Tread Width
Goodyears ....... 9.8 ............. 7.7 ............. 11.4 ........... 9.2
Firestones ...... 9.4 ............. 8.2 ............. 13.5 .......... 10.4
All dimensions are based on the measured rim widths of 8.5" front, 10.0" rear.
Old Apr 19, 2010 | 12:25 AM
06 C6 vert's Avatar
06 C6 vert
Originally Posted by FortMorganAl
I was pleasantly surprised that my experience was the opposite. The original Z51 SC tires pulled 1.1G once on a turn I do often and were normally in the 1.05 range. the Firestones did 1.1 almost out of the box and are now routinely at 1.15G. Seat of the pants says the Firestones are softer going into the turn but the meter says they pull harder in the middle. Coming from the Goodyear F1s, I think the OP is going to be VERY pleasantly surprised.
Same for me , the initial turn in is very much different than the OEM Gy's but the cornering power and steering accuracy is better on the FS tires. It took me a couple of weeks to get used to the change of the FS tires compared to the OEM's is all.
Old Apr 19, 2010 | 12:47 AM
cclive's Avatar
cclive
This is a misprint on TireRack site...the section width is the same....the Firestone site has the correct dimension:http://www.firestonetire.com/tiresel...roduct_ID=1079
At 13.5 inches, it would look silly on the rim.
Old Apr 19, 2010 | 01:07 AM
agp45's Avatar
agp45
I also just had wide ovals installed on 05,z51. Much less noise and better ride than GY f1super cars. All four, alignment,road hazard, $1070 installed! What pressures are you running on wide ovals! Tire tech said 35psi. Thanks
Old Apr 19, 2010 | 01:11 AM
cclive's Avatar
cclive
30 psi like it says on the door jam. 35 cold will wear a nice stripe right down the middle of the tire, especially in the rear. As long as the tires are the OEM size, the manufacturer of the car sets the tire pressure, not the tire maker.
Old Apr 19, 2010 | 07:21 AM
POPA-VT's Avatar
POPA-VT
All Four.
I'm sure that does help. I was in Rocky Mount once in 1967. Train tracks ran right done Main St. then if I remember correctly.
Old Apr 19, 2010 | 10:32 AM
LeMans05C6's Avatar
LeMans05C6
Default Firestone Firehawk Wide Oval RFT - cornering experience.
Originally Posted by mitchydkid
People keep talking about how quiet and soft they ride. That is fine, no criticism here, but can anybody who likes taking corners fast comment on how good they grip. My GY SC gripped like crazy (when new) and I am SOOOO disappointed with the Hankooks I bought. I read lots of reviews that said Hankooks were good, but my stock C6 can slip these crappy tires with very little effort. How do firestones compare to GY in the grip department? Not just straight line, but in the corners?
I was debating the Hankooks but i think your review of them in corners has steered me away from them. My car is a daily driver and i bought it used with the Firestone Firehawk Wide Oval RFTs on it. I took it to my first HPDE event in February (not the warmest month even in TX) and i thought the Firestone's held up really well.
**You may take my next thoughts with a grain of salt since it was my first HPDE event and no tires for comparison***
Having definitely learned cold vs warm tires with the HPDE event, once these are warmed up they grip very nicely. They are controllable at the limits and if you push them just beyond they seem to be quite controlable. The last 2 sessions of my weekend i had a few small controlled slides. Far from a giant drift but that point to where the back end isn't exactly in line with the front but your still in control of your car. I haven't ever driven my car with anything like the race/street tires like the Bridgestone Potenza RE-11 (they looked like more of a racing tire), but for a good balance of daily driving and the 3-4 times a year HPDE i think these would be a good balance.
I have heard that Texas Motor speedway does a corvette event and actually switched to these tires for that event.
Old Sep 16, 2010 | 06:19 PM
  #33
TexasHiwayman's Avatar
TexasHiwayman
Default Love them
I put @40000 on a set of the Firestones on my 99. Still had at least 10000 left on them when I sold the car. I have 23000+ on the set on my 06. They handle great and look to have another 20000+ in them. Front driver side tire ate one of those concrete form nails at @3000 miles. Drove car at 30-35 mph for 4-5 miles at 0 pressure. I had bought the tires at Discount (matched Tire Rack's price plus $19 per tire to mount + $90 sales tax = $1150-1170). They repaired the tire for free and told me to keep an eye on it. 20000 miles later still same as other 3.
Old Sep 16, 2010 | 06:57 PM
  #34
hawkgfr's Avatar
hawkgfr
I am liking mine so far...almost 10k on them....I got 21k on the good/craps. They are quieter and more sticky....though I'm waiting to see how they do in the colder weather.
Old Sep 16, 2010 | 07:17 PM
  #35
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
if they are sticker than the badyears now, they will be better in cooler weather............ wait...... "cooler weather"......in South Carolina?...................
Old Sep 16, 2010 | 07:30 PM
  #36
qcdoc1's Avatar
qcdoc1
St. Jude Donor '08-'09
Cooler weather in SC? Yes it does get a little cool down here and the FSWO stick very well in cold and wet...
Old Sep 16, 2010 | 07:48 PM
  #37
dpigguy's Avatar
dpigguy
hey wolfdog, aren't you suppose to be taking it easy? typing is pretty stressful for someone in your "condition"
My experience with the FSWO's are similar in that they are much more quiet vs. the GYF-1's but I find that they have less grip and tend to break loose alittle quicker then the F-1's. but then, since I drive like a little ole lady, they fit me very well
To Firestone FireHawk run flats
Old Sep 16, 2010 | 08:07 PM
  #38
goatts's Avatar
goatts
You do realize that the Hankooks have a higher treadwear rating then the SC's so they are not going to grip as well and the Firestones are hard as a rock. The Kumho XS or Potenza will be your best bet for grip, they each have a 180 UTQG. A lot of guys like the PS2 also.
Old Sep 16, 2010 | 08:21 PM
  #39
hawkgfr's Avatar
hawkgfr
yea man...we have cold weather in Jan/feb...and woo hoo...the Vette loves it.
Old Sep 16, 2010 | 09:52 PM
  #40
laconiajack's Avatar
laconiajack
I'm curious, did you consider the Michelin Pilot Sport A/S Plus Run-Flats?
