Dripping mirrors
What I've done is just wash the car as normal. Then turn the mirrors to let the water drip out for a minute or so. The take "The Absorber" drying towel and force a corner (or two) into the space and suck out whatever water is left.
This obviously would be the option when you don't have a blower (or combine it with the blower).
Just my .02
It seems that from the factory, some mirrors DO NOT DRIP AT ALL, some drip VERY LITTLE, and some drip EXCESSIVELY as if the water builds up and is trapped, bleeding out little by little DESPITE A BLOWER.
I have owned two C6's. The first had NO issue at all even without a blower. When I read such complaints on the forum years ago, I simply could not relate because I did not have the problem (though I could relate with the tail light seals).
When I got my second C6, I could not believe the difference. It would literally leak for hours despite using a strong blower and regardless of the temperature (our summers are above 100 to 11x). Like you, mine leaves scummy mineral deposits that requires a polisher to eliminate.
I either wrap the mirrors in a plastic bag (similar to what Vette Suspension does) or avoid a direct spray to the mirrors. If I do spray the uncovered mirrors, I use a blower (a Toro Ultra 235 mph) and, after the car is dry, place a piece of paper towel against the base of the mirror to absorb the slow leak (affixes itself by the moisture leaking out). I then check back on it for the next couple of hours, swapping out the paper towel. Very annoying.
Again, nothing against those offering the blower advice, but the fact that some C6's leak even with a 235mph blower and others do not whatsoever indicates that something is occurring at parts, assembly, etc.
Regardless, hope you find a solution
I use to wrap each mirror in Saran Wrap prior to washing.
It did the trick of keeping water out of the mirrors.
But it was a pain in the neck to use especially on windy days.
So I just purchased mirror seals and they work great.
But they're a pain to put on.
- I use my CR Spotless water filter to take ALL the minerals out of the wash/rinse water. Dirps will absolutely never spot! Auto Geek has them. http://www.autogeek.net/cr-spotless-water-systems.html
- Use a leaf blower and not only blow from the rear of the mirror, but also blow from the front. A 200 mph blower aimed from the front will create a vacuum effect and suck the water right out.
