The C6 - two fuel tanks or one
Welcome to 1996 .
J/k. The giveaway in the design/placement of the tanks is in the fuel tank filler. In the C4's, it was centered high in the back, just ahead of the rear bumper behind the hatch glass. Starting w/ the C5 in MY97, the filler moved to just behind the drivers door, to accomodate the tanks being moved forward of the rear axles. This created the problem of how to fit the "tank" around the central tunnel, as putting it above it would have had it sitting right behind your head. By going to the dual tank design, they got the tank where they wanted it while simultaneously opening up a huge cargo area.
Welcome to 1996 .
Received 1,101 Likes
carryover design
Previews of coming attractions...
http://forums.corvetteforum.com/show....php?t=2430894
I believe this is the 8-page PDF:
http://www.hessh.de/Corvette/FuelTankSystem.pdf
A friend of mine is getting a supercharger put on his C5 Z06. I believe he said his fuel sender/pump is accessible from the side so the tank doesn't have to come out of the car. That is a major PITA for the C6.
Received 2,051 Likes
St. Jude Donor '13
St. Jude Donor '08
#33
Received 1,920 Likes
#36
More so if you have a larger automatic transmission. It's supposed to be a little easier with a manual transmission. The last time I looked under that area of my car it appeared to be easier to get to the transfer tube. My car is a manual. The fuel filter is inside the tank. Which is a (what were they thinking?) kind of thing.
#37
