Help
Old May 22, 2010 | 04:55 PM
VettinFan's Avatar
VettinFan
Thanks for posting the update. There are so many possible scenario's, especially when it comes down to electrical. This is yet another one for the books.
Originally Posted by joyryd_1
4. Remove Battery to check connector X184 of a cable. The tech said it was an 86 pin connector. Found male end of pin 25 not fully seated in connector. Repaired connector and tested good.
Old May 22, 2010 | 05:44 PM
z51vett's Avatar
z51vett
Originally Posted by AORoads
sounds like something's loose, like a batt cable, cable to alternator, etc. battery tested out good, right?
Have the wiring at the starter checked for loose connection.
z51vett
Old May 22, 2010 | 05:52 PM
vettedoogie's Avatar
vettedoogie
Might want to make a sticky out of this one!:
