touring alignment
Old May 24, 2010 | 09:01 PM
Mel 2001's Avatar
Mel 2001
Default touring alignment
Could someone give me the alignment specs for better tire wear on my 06 F55 A6 vert? (non aggressive driving) I can't seem to find it on the search feature.
TIA
Old May 24, 2010 | 09:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If you are looking only for best tire life, then I would go for:
0 camber front & rear
0 toe front and rear
Caster isn't too important.
Lots of people complain about wearing the inner edges of their tires from slight negative camber, but toe out seemed to wear my tires a lot more.
Old May 24, 2010 | 09:40 PM
Jeff78's Avatar
Jeff78
Jim is pretty close.
I align roughly 1500 cars yearly including many Vettes from our club. Best specs I have found so far is 1/4 negative camber both sides, match the caster left to right and 1/8" total toe-in.
Old May 24, 2010 | 11:21 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Mel, take a look at post #7 by Modshack on here: http://forums.corvetteforum.com/c6-c...nt-issues.html
And then note this comment from another time by eboggs:
12-07-2007, 02:17 PM #5
eboggs_jkvl
CF Senior Member
eboggs_jkvl's Avatar
If you want to keep the car for Xcross, then the specs shown are fine. If you want to set the alignment for maximum tire mileage get that camber DOWN. Put the camber on ALL 4 down to -0.1. The caster shown is fine. Set the rear toe to 0 and the front to to -0.01. You will not be able to feel any difference while you drive. If you X-cross, then you will lose a few tenths. If you X-cross, set the camber back to -0.45 up to -1.0 for racing applications.
The stock settings will wear the inside off of the tire.
http://forums.corvetteforum.com/show....php?t=1795091
Elmer
Old May 24, 2010 | 11:26 PM
K9KUZ's Avatar
K9KUZ
Old May 25, 2010 | 12:06 AM
Mel 2001's Avatar
Mel 2001
Thanks for all your input. I will take this info to the alignment shop.
To touring alignment
