High speed Question.
The GS has the LS3 engine but I've seen numbers like the LS2 cars or even slightly lower, because of the aerodynamic drag from wider fenders and tires.
Not that there is any practical use to those speeds...
I don't know about rolling resistance on the tires, but aerodynamic drag goes up as the square of the speed. In other words, going twice as fast takes four times as much power.
The LS2, LS3 and Z06 Vettes run out of TQ (falling HP curve) by the time they get to peak velocity. 6th gear is too tall for peak velocity work.
In any event, this (albeit) fine distinction only raises the peak velocity be a couple of MPH at most, but does give better access to near peak velocity numbers.
, Mitch Any relations to the Alsup's gas stations?
Good point.
It is the Force of aero drag the goes as the square of speed. work/energy is force times distance and power is work/energy per unit time, so power to overcome aero drag goes as the cube of speed.
I've had my Vert out on the Bonneville Salt Flats, it took five miles to hit top speed, at 185 (that was on the speedo, not GPS). And that was with a lot of altitude. At sea level that would have been more like 192 or so (the denser the air, the more power you make, the faster you go). The mirrors pop back out at 150. Bonneville's a 24 hour drive each way from Dallas.
A car with a lot more power would get to top end a lot faster and need less road, I'd imagine. You have 800 horse Vettes hitting 200 at the Texas Mile, and they likely don't have another 20 MPH to go beyond that.
There is no speed limit on federal land. Places like dry lake beds and salt flats. Extra benefits of those places includes they tend to be pristinely flat, you can see forever, no critters, no plants, and generally no people.
And if it goes bad out there, in the middle of nowhere, you are SO screwed . . .
If you just want to drive real fast legally, check out The Texas Mile, and the Big Bend Open Road Race. Fun stuff.
