Paddle Shift Automatic
Old May 31, 2010 | 10:28 PM
clarkakirby's Avatar
clarkakirby
Default Paddle Shift Automatic
I have a 2010 Grand Sport with the 6 speed automatic transmission. I know you guys have a fix for just about everything.
The car's transmission does NOT shift when the paddle is pushed; there is a lag. I have not noticed such a lag when downshifting. If I shift up a gear at the redline, the engine hits the rev limiter before the transmission shifts. I don't want to shift early...I want it to shift exactly when I hit the paddle. So, what do you recommend to speed up the response of the paddles being pushed to go up a gear?
-Clark
Old May 31, 2010 | 10:52 PM
Mike Green9's Avatar
Mike Green9
Same problem for all A6's. The cure is a a software tranny "tune", that can make the shifts instantaneous. The only down side is possible warranty issues on powertrain related problems.
I may have this done after my warranty is over. For now, I time the shifts accordingly.
M...
Old May 31, 2010 | 10:58 PM
CSixDude's Avatar
CSixDude
You'll probably need to get an aftermarket transmission tune done to reload your transmission calibration data in the TCM. The way the A6 transmission shifts in stock form is pretty bad, in all modes. The only way I know to fix it is with a transmission tune from a reputable tuner.
There are some hand held units out now that will let you load a transmission tune yourself at home. The EFI Live FlashScan V2 tool costs about $800 and will let you do it. But you'll probably still want a professional tuner to supply you with the updated calibration data. There are several good tuners on this site, check the Scan & Tune section of the forum.
Old May 31, 2010 | 11:05 PM
CSixDude's Avatar
CSixDude
By the way, I'd like to say that after driving a car both before and after a tune, a good transmission tune will totally change your driving experience. Once tuned, the transmission will progressively downshift like it should when you push on the pedal, and the terrible 4 gear downshift and lag you get when you give it the gas will be gone. A lot of it can be blamed on the torque management of both the engine and transmission, and the shift points are all set to try to keep the rpms low for gas mileage, so it won't let the car downshift when you need it to. A car with a good tune in it, will feel like a completely different car.
Personally, I don't know how GM could even release a car on the market with the transmission set up as bad as it is on the Corvette. I guess it's a sign of the times. And then to rub salt in the wound they threaten you with voiding your warranty if you try to fix what they screwed up to begin with. Pretty pathetic if you ask me.
Old May 31, 2010 | 11:15 PM
mrgillies's Avatar
mrgillies
My biggest issue is when I go for a fast start, 1st gear limiter kicks in all the time when I go WOT in full auto mode, I have to lift the throttle a little to give it time to shift, this wasnt an issue before I had the Vararam and Diablo tune installed. Dealer checker her out and said there is nothing wrong with the car, guess I'll have to get a COW tune when I get the Edelbrock and headers installed to make it more responsive.
Old May 31, 2010 | 11:45 PM
C7/Z06 Man's Avatar
C7/Z06 Man
I have a 2010 GS A6 too and noticed the up shift lag in the sport mode; only tried it once or twice to date. The paddle shift only works in the sport mode. I have not tried the paddles with the completive mode on also, it may be worth a try but I have a feeling that it may not do a thing but I could be wrong.
Old Jun 1, 2010 | 12:04 AM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by clarkakirby
...So, what do you recommend to speed up the response of the paddles being pushed to go up a gear?
-Clark
For best paddle-shift response, put the gear lever in "S" and select Competitive (COMP) Driving Mode.
COMP mode is selected by pressing the ACTIVE HANDLING button on the console quickly two times. Be aware that this defeats the Traction Control system.
If you're drag racing, let the A6 do the shifting... it's faster than paddle-shifting and you don't risk hitting the rev limiter.
Depending on the situation, paddle-shifting can be a half-second slower than auto-shifting!
More details and videos:
http://forums.corvetteforum.com/c6-c...g-problem.html
Old Jun 1, 2010 | 12:09 AM
CO Lightfoot
Try COMP mode. It is a definite improvement:
Old Jun 1, 2010 | 12:11 AM
Vette Suspension's Avatar
Vette Suspension
Old Jun 1, 2010 | 09:37 AM
08vycpe's Avatar
08vycpe
The lag in the downshift is because the tranny is programmed to "rev match" the newly selected gear to the speed of the vehicle. Owners of manual shift vehicles would have to try and learn how to do the heal/toe shift to simulate the rev matching downshift.
The tranny upshifts in less than 1/2 second. You can't even shift a manual that fast. It does shift quicker and harder when in sport mode. It holds the gear a little longer also when in sport mode but only if you are driving in a spirited manner.
Old Jun 1, 2010 | 10:45 AM
aks801's Avatar
aks801
From what I've read on here, Chuck Cow looks to be a top guru for A6 reprogramming. Lots of great user reviews.
Old Jun 1, 2010 | 03:55 PM
bps999's Avatar
bps999
I apologize for nitpicking here but I can't help it. Heel-toe technique is for rev matching while braking (and is about the funnest part of driving a car). Rev matching while not under braking does not require heel-toe.
As for speed of upshifts, the auto upshift itself may be 1/2 sec, on par with a typical manual time, but the delay that occurs between when you press the paddle and when the upshift begins is a sepatate issue.
Old Jun 1, 2010 | 04:27 PM
bagwell's Avatar
bagwell
this is the reason I still don't like the A6....MN6 FTW!
Old Jun 1, 2010 | 05:18 PM
res0n0xg's Avatar
res0n0xg
You will always have that "delay" feeling with the A6, that's just the way the automatic works, if you mash the pedal to the floor, it won't just be an instantaneous upshift unfortunately. Even, after your tune.
I know this because I have a tune with my A6 for my 08 C6, and do not get me wrong, before the car wouldn't even chirp the tires on the 1-2 shift, now I can leave a strip of rubber almost 10 feet long going through 1-2 shift at WOT sometimes with my A6 and get the car a little sideways, so a tune is definitely something you will want, it still won't feel perfect though.
At least that's in my experience....
Old Jun 2, 2010 | 02:21 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thanks Very much!
Thanks Very much!
YES, we can fix it up and make it a whole lot more fun....
Give me a call any time and I'll get you fixed up right.
Chuck CoW
Old Jun 2, 2010 | 03:30 PM
davanz's Avatar
davanz
I know the answer to this may be subjective, but with a Chuck Cow tune, how does the transmission shift feel in D? I have had transmissions rebuilt before which afterwards shifted with too much of a "bang" or "hit" even when accelerating gently. That I do not like the feel of. I would welcome a more responsive and aggresive shifting in S and paddle mode but still want to retain the gentle shifting when I am in the "boulevard cruiser" mood which is much of the time. Also, is it possible to get the trans tune only, without the engine tune?
Old Jun 2, 2010 | 04:06 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Talk to some of the guys on the forum.....
Talk to some of the guys on the forum.....You've got a few thousand guys to chose from.
Part throttle shifts are smooth like butter and WOT shifts can strike the tires....
All shifts are completed quicker and more precise, however I am painfully aware of the pitfalls of the old school shift-kit that you could not "turn off" even when driving easy.
I spent a lot of time making sure that I minimized complaints and after all this time I've honored the feedback of everyone who has the tune which has helped me "polish" the tune to what it is now.
I can definitely say at this point that it is the most refined A6 calibration that anyone has seen to date....
Best thing is with me, come to my shop and I'll install it and let you drive it..... If you don't like it, I'll take it out and you owe me nothing.
Can't beat that.
But, BEWARE! It's a TRAP!
I guarantee that you'll go home with it!
Chuck CoW
To Paddle Shift Automatic
Old Jun 2, 2010 | 04:28 PM
davanz's Avatar
davanz
Chuck, any thought of coming to Erueka Springs Ark this year? It is Sept 30 thru Oct3 and I would probably want to have your tune then. Or, when could your next Dallas, Texas visit be?
Old Jun 2, 2010 | 07:39 PM
Chuck01's Avatar
Chuck01
Old Jun 2, 2010 | 09:05 PM
bob guzzy's Avatar
bob guzzy
I had that problem with my 08 a6, I found the cure, I replaced the car with a manual I couldn't be more happy.
