Navigation Power Button
Old Jun 2, 2010 | 10:17 AM
Dif's Avatar
Dif
Originally Posted by Eppieguy
I have a 2009 C6 w/ Factory Nav. I was out Sunday night and tried to turn off the radio and when I pressed the button, nothing, pressed again, nothing, pressed and held down, nothing. Thought I was going crazy so today I looked it up in the manual and yes, that's the way you are supposed to turn it off but mine doesn't! Anybody else have this issue?
Do you have the NAV screen showing when you try to shut off the radio?
I have an 09 with NAV and....
If I'm listening to the radio, then pull up the NAV screen, it won't shut off until I go back to source ( radio ) ....
Then when I push the button, everything shuts off.
Maybe there is something wrong but,.. just figured that's how it works and has not been a problem.
If you have the radio showing and it won't shut off, then I guess there is a glich/problem
Hope this helps
Old Jun 2, 2010 | 10:34 AM
BEZ06's Avatar
BEZ06
Originally Posted by cclive
.....When I start the car the next time, the CD will start up and it takes a few seconds before I can turn the volume down...sometimes embarassing with the top down!
Well Chris, that's what ya get for driving around with your volume blaring!!!
What were you listening to - big band, disco, punk rock,.....???
Bob
Old Jun 2, 2010 | 10:44 AM
Eppieguy's Avatar
Eppieguy
Hope this helps
Ok, I'll give that a try, I can't say that I have ever tried to turn off the radio before so maybe I'm just doing it wrong. I'll try going to the radio screen and hitting the button and see what happens. I'm used to my 2009 Tahoe (Daily Driver) and no matter what is on my screen if I hit the volume button everything shuts off.
Old Jun 3, 2010 | 11:45 AM
Eppieguy's Avatar
Eppieguy
Default Update!!!!
UPDATE.......................
Nothing wrong with the unit, I have a Billet Aluminum **** on the radio and it doesn't push in far enough to turn it off, I took the **** off last night, pushed the volume button and the radio went off.
Thanks for all the help guys!
